| Re: Microfiber Everywhere - Let's sort them out! Answer Key
1. color difference is correct
2. I use standard, HD has a foam core and holds more water, since I use a leaf blower first, no matter
3. HD typically holds more water, yes.
4. Designed for polish and wax removal only, has a slight nap to pull it away from surface and both sides are similar
5. See Above
6. yes, I believe same. Indigos and teal edgeless are same for sure
7. slightly more plush on one side, but not much is noted
8. quick detailing, spray waxes, and final buffing
9. dash, interiors, underhood, non-painted areas (Mango's are general purpose)
Miracle Towel -- nice a plush but not super plush, work well for wax removal if you prefer a thicker towel and can be used for washing too. Quick detailing would be another option. |
