Go Back   Auto Geek Online Auto Detailing Forum > Auto Detailing Forums > Auto Detailing Tools and Accessories
Featured Photos
by admin
531 photos
16 comments
by admin
531 photos
16 comments
by admin
531 photos
16 comments
by admin
531 photos
16 comments
» Autogeek Car Care Products
Our car care cleaning kits are thoughtfully assembled by expert car care professionals
Tags:
Reply
Thread Tools Display Modes
  #1
Old 06-10-2008, 09:14 PM
Member
Wool vs foam pads?
Does anyone know the difference between how wool pads and foam pads perform? What are the pros and cons to using one over the other? I don't really see manufacturers comparing the two so maybe theres a reason? Thanks
  #2
Old 06-10-2008, 09:31 PM
detailgod's Avatar
Re: Wool vs foam pads?
foam
cons
gets hotter= easier to burn paint
harder to control= pad jumping and hoping all over
does not cut as fast as wool
pros
finishes better=less swirls if any
holds polishes longer= quick spritz to pad and start working again
wool
cons
use more product
having to spur them all the time cuts down on the life of them
need to be very very very skilled to finish swirl free( it can be done)
pros
does not get as hot as foam
better control= does not jump like foam
cuts faster( could be a pro and a con)
there are just what i have noticed. i am sure more people will chime in cause i know i am forgetting alot
  #3
Old 06-11-2008, 04:52 AM
TOGWT's Avatar
Detailgod I think you covered most of the relevent points-
Foam Pad Type Pros & Cons:
Foam pads absorb polishes quickly reducing polish and pad performance; because most of the polish is trapped below the working surface of the pad. Priming a foam pad with distilled water saves on product use by reducing polish absorbs ion and also avoids ‘dry’ polishing. Another reason for priming a foam pad for use with a rotary polisher is that it makes for a smoother polishing movement without causing the pad to ‘hop’ over the surface. Like foam a wool pads abrasive ability is closely tied to its composition i.e. ‘soft’ wool has less cut
How fast - the general rule is; the bigger the pad the faster the cut, the coarser the compound, the faster the cut, the more aggressive the pad, the faster the cut. Wool cuts faster than lambs wool, foamed wool is next and then foam. You pay the price for polishing too fast with swirl marks caused by the compound and pad combination.
Wool:
Pro- faster cutting generates less heat and therefore leaves the surface cooler (use on aerodynamic parts, spoilers etc and plastic bumpers)
Wool, dissipates heat through the fibres
Removes heavy oxidation much more efficiently than a form pad
Make certain to spur the wool fibres when it loads up with product.
Con- can leave micro marring (buffer trails)
Use more polish than foam pads
Don’t overwork the polish as wool will break diminishing abrasives faster than foam, the surface lubricants will dry up faster and you could end up dry buffing unless you’re careful.
Foam:
Pro - gentle (non-aggressive) light to moderate cutting
Con - heat paint quickly by transmitting the heat back to the surface, but leaves the paint surface with a smooth finish ready for application of last step product (LSP) Wool is also much safer to use on heat sensitive parts of your car. Aerodynamic spoilers and bumpers can be buffed with wool with a higher margin of safety than foam.
General note-
a) Cut with wool pads; finish with foam pads, foam produces the most surface friction heat
b) Limit speed on wool pads to 1500RPM
b) Compared to foam; wool pads have a larger available cutting surface area per square inch, which is due to the structure of the individual wool fibres compared to that of foam, allowing faster cutting action with less friction heat, utilizing less downward pressure
c) With a PC, a smaller pad (less surface area) will generate more ‘spot’ heat and is more aggressive, with a rotary, a larger pad's edges are moving much faster, so it has more cut (a PC at speed # 6 will transfer heat (up to 130 0 F) to the backing plate and may delaminate the Velcro™)
  #4
Old 06-11-2008, 11:53 AM
67Customs's Avatar
If you want the best of both worlds, do your cutting with a wool pad and finish with a foam pad. You can cut easier and quicker with wool and the hopping and heat generation is less with the softer foam pads that are used for finishing for a better finish then wool.
I am also a big fan of LC's foamed wool.
__________________
What if the Hokey Pokey IS what it's all about???
  #5
Old 06-11-2008, 01:24 PM
ASPHALT ROCKET's Avatar
Also with wool it levels the paint better and this will in turn provide you with a better finish on the vehicle.
  #6
Old 06-11-2008, 02:26 PM
bryansbestwax's Avatar
I agree, wool to cut and foam to finish, there are times when foam cutting pads are nice, like single stage paints.
  #7
Old 06-11-2008, 02:43 PM
killrwheels@autogeek's Avatar
Moderator
wool is typically a cutting pad as noted as best left to rotary use. Foam pads are general pads and different abrasive levels from finishing to quite aggressive.
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Review -Edge 6" wool pads trlblazer3 Porter Cable 7424 & Buffing Pad Forum 6 04-25-2008 03:41 PM
Foam Pad Selection Criteria TOGWT Auto Detailing University 2 03-25-2008 09:49 PM
NEW PRODUCT-Edge 2000 PLUS 6 Inch Wool Buffing Pads Meghan New Car Care Products 3 09-10-2007 08:49 PM
The Edge 4 inch DoublePrecision™ Cyclo Foam Pads Meghan Cyclo Polisher and accessories 13 02-11-2007 10:45 PM
Edge 2000 4" Pads - PRODUCT REVIEW MikeyC Auto Detailing Tools and Accessories 12 11-15-2006 05:59 PM
» October 2008
