» Paypal Bill Me Later | |  | |
07-10-2006, 11:20 PM
#1 | | Senior Member
| Grey vs blue 6.5" PC pad...
What's the practical difference between the two pads...the description says they're used for the same thing. I already have the grey and use it to apply NXT. Should I use the blue pad instead?
07-10-2006, 11:53 PM
#2 | | Senior Member
The gray pad is used more for applications, the blue pad can be used for application and/or removal, I still say remove anything by hand with a mf, on the other hand you can get MF bonnets to fit over your blue or grey pads to remove stuff, I have some, but haven't used them yet, I just feel safer doing it by hand.
07-11-2006, 07:41 AM
#3 | | Senior Member
| Quote: |
Originally Posted by Excessive Detail The gray pad is used more for applications, the blue pad can be used for application and/or removal, I still say remove anything by hand with a mf, on the other hand you can get MF bonnets to fit over your blue or grey pads to remove stuff, I have some, but haven't used them yet, I just feel safer doing it by hand. |  blue for application/removal, although the bonnets look soft and yummy, just my luck i get a piece of sand or whatever in the bonnet and its SWIRL city all over again......ill maybe use the blue for removal and finish with the M.F. towel.
07-11-2006, 09:18 AM
#4 | | Senior Member
OK, I'll stick with the grey pads then. I used it to apply the NXT quickly. It was much easier to lay a thin coat down with the PC. I still had to use the foam applicator pad for spots where the PC couldn't reach.
I'll also stick with removing the wax with a MF towel. It was so easy to do that there is no point in chancing putting in a swirl or scratch with the PC.
07-11-2006, 10:38 AM
#5 | | Senior Member
| Quote: |
Originally Posted by Excessive Detail The gray pad is used more for applications, the blue pad can be used for application and/or removal, I still say remove anything by hand with a mf, on the other hand you can get MF bonnets to fit over your blue or grey pads to remove stuff, I have some, but haven't used them yet, I just feel safer doing it by hand. | I would now after giving it some thought,think its safer with a microfiber bonnet over a lambs wool bonnet for xtra cushion for a final buff..after all it is M.F. but that possibility of a little piece of sand keeps coming into play
A/G has a nice little bonnet package for the 7424......
07-11-2006, 10:06 PM
#6 | | Senior Member
| Quote: |
Originally Posted by BILL I would now after giving it some thought,think its safer with a microfiber bonnet over a lambs wool bonnet for xtra cushion for a final buff..after all it is M.F. but that possibility of a little piece of sand keeps coming into play
A/G has a nice little bonnet package for the 7424...... | That would suck, I want to try the bonnets but have similia fears, I feel safer doing it by hand, plus you get to feel the results of your hard work, as goofy as that sounds.
07-12-2006, 06:11 AM
#7 | | Senior Member
| Quote: |
Originally Posted by Excessive Detail That would suck, I want to try the bonnets but have similia fears, I feel safer doing it by hand, plus you get to feel the results of your hard work, as goofy as that sounds. |
NO NOT GOOFY, I  But im going to try it on the trunk and ill let you know how it is...... |
#8 | | Moderator
you could use bonnets alone with a soft foam core (finishing pads). Remember you need a little stability to help remove the wax/sealant. And I have found the blue pads to be a touch softer initially, but seems my grey pads seem to get softer after first use. (maybe just my imagination)
07-12-2006, 06:14 AM
#9 | | Senior Member
I Would use the M.F. bonnet on top of a lambs wool bonnet as in the 7424 bonnet package as a very last buff....... low speed......3
07-12-2006, 09:25 AM
#10 | | Senior Member
| Quote: |
Originally Posted by Excessive Detail That would suck, I want to try the bonnets but have similia fears, I feel safer doing it by hand, plus you get to feel the results of your hard work, as goofy as that sounds. | I agree...not goofy at all. To me the satisfaction comes from sight and touch. I love the shine but I also love feeling how the mf towel just glides effortlessly over my newly polished and waxed car.
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | » Popular Product Links | | | » June 2013 | | S | M | T | W | T | F | S | | 26 | 27 | 28 | 29 | 30 | 31 |
| 1 | 2 | 3 | 4 | 5 | 6 | » Car Care Brands | | | |
