Well, I am really digging all the stuff I got from autogeek in my first order. Per my other thread, the foamgun rocks. I'm now testing the carpet brush attachment for the PC.
I was wondering what everyone's carpet cleaning technique is?
I'm practicing on the dirty old removable driver's mat first. I have some heavy duty carpet cleaning foam and also some very diluted Simple Green. I've used the foam and Simple Green with good success on some interior entry rugs.
Do you vacuum up the cleaner after you're done scrubbing?
Do you spray clean water to act as a rinse first?
My plan was to:
- Vacuum thoroughly with a shopvac.
- Spray cleaner, let it soak.
- Scrub with the PC and scrub brush attachment and/or Meguiar's interior brush (for spots where the PC won't fit.)
- Vacuum cleaner with a Hoover steam vac and hose.
- Spray some clean water to "rinse"
- Vacuum cleaner with a Hoover steam vac again.
- Blot dry carpet with a clean towel.
I'm concerned with mold and/or mildew forming in the car if I use too much liquid and the carpet doesn't dry adequately. Are auto carpets resistant to this stuff? Is there anything to worry about here?
