| Well, hate to tell you but the first time you cut through that 2 years of dirt and grime, you'll probably spend 6-8 hours and some elbow grease. But after that, maintaining the shine will be a breeze!
The procedure you listed is very good. Swirl removing, cleaning and polishing will all happen somewhat simultaneously with the PC 7424. I would recommend using the XMT line of polishes for that step. Either use XMT 4 or 3 (depending on the level of swirls and scratches), step down to XMT 1, and then use the XMT finishing glaze. These can all be applied by the PC 7424. Then, just pick whichever wax or sealant you want to top with. I say this because the XMT line was the first one I used, and is also very easy to use for the first time polisher.
Alternatively, if you want to clean, polish and seal in one step, use XMT 360 which will do all of this at once. However, if you have a lot of swirls or scratches, you may not be able to do all your paint correction with this because it's not super aggressive.
Do all of that after a real good wash and clay and you should be set. Good luck! And post pictures or any questions along the way so we can see what you are working with.
__________________ Paul 2000 Corvette 1965 Chevelle |
