09-09-2007, 02:03 PM
|  | Senior Member | | Join Date: Nov 2006
| | | Caustic Chemicals??? I Have A Few All Purpose Cleaners That I Bought From A Detailing Shop And There Caustic . Is That Bad?
__________________
names tom i live in nj with my wife and my daughter samantha born 8/23/06 shes so awesome .we love her so much! |
09-09-2007, 04:54 PM
| | | bumpyyyyyyyyyyyyyyyyyyyyyy
__________________
09-09-2007, 05:03 PM
|  | Senior Member | | Join Date: Jun 2007 Location: CA, bay area
| | | Well.....Generally yes, but it really depends on what you use it on. I think anything over a PH of 12 is considered caustic. I stay far far away from acidic or caustic cleaners as they can damage some surfaces. |
09-09-2007, 05:14 PM
| | Quote:
Originally Posted by Thejoyofdriving Well.....Generally yes, but it really depends on what you use it on. I think anything over a PH of 12 is considered caustic. I stay far far away from acidic or caustic cleaners as they can damage some surfaces. | im slowly not useing them anymore the only thing i have thats caustic is an all purpose cleaner ive been useing on my dash board and its now removing the dye
__________________
09-09-2007, 05:36 PM
| | Quote:
Originally Posted by trhland im slowly not useing them anymore the only thing i have thats caustic is an all purpose cleaner ive been useing on my dash board and its now removing the dye  | Oh no! you werent using it on the vinyl were you  |
09-09-2007, 05:40 PM
| | Quote:
Originally Posted by Thejoyofdriving Oh no! you werent using it on the vinyl were you  | the stuff i used is from carbrite its ment for vinyl leather ect . the companys a high volume commercial detail company. and what ive noticed is these chemicals really arent ment for guys like us who clean our cars all the time .there just to strong and over time have these affects. so im stearing clear from them . at leastrit was my dumptruck not my new pick up.
__________________
09-09-2007, 07:20 PM
| | Quote:
Originally Posted by trhland the stuff i used is from carbrite its ment for vinyl leather ect . the companys a high volume commercial detail company. and what ive noticed is these chemicals really arent ment for guys like us who clean our cars all the time .there just to strong and over time have these affects. so im stearing clear from them . at leastrit was my dumptruck not my new pick up. | WWWWWWHHHHHHAAATTTTTTTTTTTTT?????!!!! Caustic+leather/vinyl=no no |
09-09-2007, 10:46 PM
| | Quote:
Originally Posted by trhland I Have A Few All Purpose Cleaners That I Bought From A Detailing Shop And There Caustic . Is That Bad? |
Tom,
How do you know they are caustic (as opposed to neutral, or acidic). I assume you do not have pH meter, and are going by what someone told you? If you have more info on the chemicals, pass it on...
Anyway, and to TJOD, pH of 12 would be extremely caustic to the point of burning your hands, etc, (think lye based drain cleaner). FTR, pH 7 is neutral, and anything below 7 is acidic, and above is alkaline. "Caustic" is casual lingo for alkaline and comes from caustic soda, the common name for sodium hydroxide. Also, you can have very agressive chemicals that are near neutral in pH, so pH is not the sole indicator of agressiveness. While I don't doubt that the chemicals TRH has are caustic as in more alkaline that pH7, I do seriously doubt that they are pH 12 chemicals. Some of the tire and alkaline wheel cleaning chemicals might make that standard, but not something intended, even for commercial use on leather or vinyl. I'm curious thouh, do you measure the pH of every chemical you use and only use pH 7 chemicals? You do realize that rain water has a pH of about 5.5 or lower if you're in LA.
DAL
09-09-2007, 11:13 PM
| | Quote:
Originally Posted by DAL1955 Originally Posted by Thejoyofdriving Well.....Generally yes, but it really depends on what you use it on. I think anything over a PH of 12 is considered caustic. I stay far far away from acidic or caustic cleaners as they can damage some surfaces.
Tom,
DAL | I have a wide range PH testing kit. It is not very accurate but it gives you a good idea of the PH. I test most of the products i use. I try to only use chemicals with in the "safe"
zone, which runs from 3 to 9. The most alkaline thing I use is 303 aerospace cleaner, it has a PH of about 9. This cleaner is safe on all water safe surfaces. So far I dont think I use anything acidic. As im sure you know the PH scale is logarithmic. So Megs APC is 1000 times more alkaline than 303 AC. I also know that PH is not the only factor that decides how strong a cleaner is, but it does play a major role. If you search through the forums you will find a thread in which one of the members tested some APC's thats how I know that Megs APC has a PH of ~12. |
09-10-2007, 05:52 AM
|  | Senior Member | | Join Date: Dec 2006
| | This thread may answer some of your questions- Acids and pH Values: |  | | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | » Popular Product Links | | | » November 2008 | | S | M | T | W | T | F | S | | 26 | 27 | 28 | 29 | 30 | 31 |
| 1 | 2 | 3 | 4 | 5 | 6 | |
