Featured Photos
by admin
531 photos
23 comments
by admin
Sema Show 2008
433 photos
10 comments
by admin
531 photos
23 comments
by admin
Sema Show 2008
433 photos
10 comments
» Autogeek Car Care Products
Ice Master Multi Blade ice scraper
Reply
Thread Tools Display Modes
  #1
Old 06-06-2007, 01:51 PM
Islander's Avatar
RMG Application Question
Once you've cleaned your paint ( I've used XMT 2 followedby XMT 1 with great results) whats the best method to apply Red Moose Glaze:
Which pad, what speed on PC, amount of RMG on pad, how long do you work the product, what size section do you do....?
Once your wax stops beading say after a month or so, will a re-application of RMG take offthe remaining wax?
Thanx for the help!
  #2
Old 06-06-2007, 02:15 PM
trlblazer3's Avatar
I'm still in the learning phase with glazes also, but I'll share my experiences. I've used a grey LC CCS pad with great results. I'm still experimenting on which speed provides the best results, I've used 4 and 5. To help prevent the pad absorbing too much product, I'll apply a small line of glaze directly on the paint and spread onto a 2x2 section. The pads seem to really absorb the glaze if applied directly to the pad IME.
  #3
Old 06-06-2007, 02:54 PM
supercharged's Avatar
Thanx for the help!
If you are using LC pads, go ahead and apply it with a grey pad. E2K pads - white. This will really "jewel" your paint.
__________________
1997 Acura 3.2 TL (sold)
  #4
Old 06-06-2007, 04:49 PM
Islander's Avatar
The trick is I used 2 different pads as I was not thrilled with the results of the 1st one. Changing of the pads made little difference. 1st pad was CCS grey and then I tried a wolfgang blue on another section of the car. The RMG did not improve the look / depth of the paint at all (2006 Black Azera)
I know the product is great, but my process needs improving. So far I've been told that not only did I use too much product ( a 1/8" ring agound most of the pad), I am not working it in enough (as I have wiped off a haze, rather than having the product go clear).
This newbie appreciates all thoughts & advice.
  #5
Old 06-06-2007, 08:07 PM
killrwheels@autogeek's Avatar
Moderator
you might wanna try the VMG by hand or mix the two and use machine with finishing pad and slower speed (3).
  #6
Old 06-06-2007, 10:49 PM
Reddwarf's Avatar
I had good results using a grey pad. See my post from a while back:
Clearkote Moose & Souveran
__________________
_____________________________________
2003 Jaguar S-Type V8
2001 Nissan Quest SE
2000 Nissan Frontier XE
"Dogs in cars again. Going away. Going away fast" - P.D. Eastman, Go, Dog. Go!
  #7
Old 06-06-2007, 10:59 PM
richy's Avatar
I just started using RMG myself a few weeks ago. I tried both using a pad which I found took a long time to work in and also I tried applying it by hand with a MF applicator and when it hazed up, I removed it with a polishing pad which gave it a good shine. That, in fariness, was using a cheap pad. I want to try it again with my lc pad to see the difference. It did shine well with the hand application though. Just my $.02
  #8
Old 06-06-2007, 11:05 PM
Islander's Avatar
The Zen Art of RMG & Go Dog Go
Do you like my hat?
I do like that hat, I like that party hat! ~PD Eastman~
Thanx for the advice, your Jag has the look I'm after. If you don't mind me asking, how much RMG did you put on the pad per pannel? At what speed did you apply it and for how long did you work it in?
Thx.
  #9
Old 06-06-2007, 11:42 PM
I like RMG especially on black. I too have noticed my pad absorbing too much product
Thanks for the tip!
As for speed, and pads, I use either a Black LC Pad, or my Sonus Blue Pad. I apply it on my PC at 4.5 with no problems. I work it in small sections at a time until is gone real thin, then remove. Sometimes I let it haze a bit, sometimes I go WOWO
__________________
-Goose
2002 Z06 Bone Stock
2001 ZR2 Bone Stock
Free Our Troops!
  #10
Old 06-07-2007, 12:57 AM
Member
I have great results with a blue pad working it in until its almost dry, but keep in mind, it is not abrasive, you do not need to work it like you do with a polish.
Also, when I use abrasives I use a VERY small amount, whereas when I use RMG I use a little bit more.
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
RMG and sealant question svtsupremecy Auto Detailing Forum 8 10-21-2007 05:31 PM
Applying RMG richy Auto Detailing Forum 2 05-19-2007 11:13 AM
Glaze + Wax Durability Question Cheetah Auto Detailing Forum 16 05-12-2007 07:33 AM
Just ordered some Souveran Paste Wax, quick question about 1st time application brig2221 Auto Detailing Forum 4 04-29-2007 09:28 AM
Question - Question - Question RPM06 Auto Detailing Forum 7 06-15-2006 10:35 PM
» December 2008
30 1 2 3 4 5 6
28 29 30 31 123
