Ok, so today I was finally able to test my new products, and for the first time I used my PC. Great Machine!
Now I decided to use it on my moderatly swirled 05 Corolla Mystic Blue. Here are my results...
Optimum Poli-Seal: Great product to apply, goes on easy, goes of easier! I used the 6" Green Edge pad to make the whole deal of the car. Used this particual method... Applied 4 dots(around 3/8" dia. each) on the pad, then with the PC of, spread it a little bit over the worked area, just enough to not have a lot on the pad. After that, spreaded into the whole area @ speed 3 just enough to have product into the working area. Then, cranked the PC to speed 6 and worked it in up-down-side-side method. After around 3-5 minutes working time, I removed with a plush MF. The results were amazing! I could see the orange peel in a whole new dimension!
It did removed a considerable amount of swirls, and it looks a lot better than before to me! No hazing from using a green pad at all! I loved it! The surface was smotth as it can be! Lots of slickness, and a whole lot more shine! Definetly a must have in every detailers bin!
Edge 2000 6" pads: Let me start by saying that I have
Not used the LC pad system and this is just a review based on first time use and experience with the Edge pads. Today, I only used the green pad, since I started late and didn't had enough time to do a whole polish. I had a little hard time trying to put the pad into the adapter, which I later figured out it was user error
I then started to apply the OPS on the roof, hood and trunk! Wow, the pads were at full contact all the time. What I loved the most out of them is that it was pretty easy to flip to the other side and continue working within seconds! What I would like to see from this pads, though, is to see some low profile pads, since this ones are pretty thick(Aaron, hint hint!
) Apart of that, I think they're excellent! Great pads, and when you compare prices, The Edge comes out to be cheaper than 2 LC, which works for me, the poor guy
Hope you enjoy the review and feel free to flame me or make any question you have!
Joey
