Quote:
Originally Posted by dksu Do you actually mix any water with SG in the spray bottle? |
no, and personally I dont agree with using water to remove. Sealants need time to cure, and water stops the process. I have found that if there is a hard spot, spritz with SG and wipe off immediately, always works !
Quote:
Originally Posted by SUV4x4 Can you expand on this?
What do you mean by "oils and fillers |
what I meant if you are using a polish or paint cleaner prior to using SG, then rewash the car or do an alcohol/water wipe down first, as they usually contain some oils or fillers that stay on the finish. It will not adhere properly and loose alot of its durability.
