04-04-2007, 06:48 PM
|  | Senior Member | | Join Date: Sep 2006 Location: La Jolla, CA
| | Best way to do headlights using pc but without the entire kit? Ok, I want to do my headlights on our 98 van. I have Meg's plast-x, wolfgang lens sealant and uv protectant - (not exact names, 2 different lens products by wolfgang in addition to the mags, and a blue coral headlight restorer bottle).
by hand does not cut it well. minimal improvement only.
What can I use these items with on the pc to get a real improvement - spot buffs? What color?
Or do I have to order a whole kit when i have so many peices?
Please advise.
Thanks!
We want to see this van over the summer and the lens are aging it falsely.
Lauren
__________________ Vette Princess ltoman 2007 Z51 Red Corvette ~ my baby 2006 Berry Red Saturn Relay ~hubby's baby 2001 Gold Saturn SW2 ~family beater 1998 Dk Green Metallic Plymouth Voyager Expresso ~ ebay mobile |
04-04-2007, 07:23 PM
| | | kllr?
anyone?
04-04-2007, 07:31 PM
|  | Senior Member | | Join Date: Jan 2007 Location: Auburn, AL / Nashville TN
| | | I used some XMT3 on my fog lights just by hand and it cleared up pretty good. Have you thought of using some 3000 grit on them and than using a polish to smooth em back up. I would try some XMT 2 on there with maybe an orange pad and see what you can do. The only thing that would be tricky are the little aligning studs on the headlights might be a pain to move around......
__________________
Frank
Thanks to AG I only wipe my butt with MF's now
04-04-2007, 07:37 PM
| | Senior Member | | Join Date: Feb 2007
| | Quote: |
Originally Posted by ltoman Ok, I want to do my headlights on our 98 van. I have Meg's plast-x, wolfgang lens sealant and uv protectant - (not exact names, 2 different lens products by wolfgang in addition to the mags, and a blue coral headlight restorer bottle).
Please advise.
Thanks!
Lauren  | I have the Same problem with my Serria 4X4 on my marker lights. Not condusive to use a convential pad(6", 4") . Would be extreamly tedious to do by hand. I am also looking for ideas. Intrested to hear the suggestions.
__________________ Brian |
04-04-2007, 07:48 PM
|  | Senior Member | | Join Date: Oct 2006 Location: Alberta, Canada
| | | Oh now who's passing who? I don't know if I would try this on my vehicles just yet but interesting question Lauren. I'm not help here babe...sorry. |
04-04-2007, 07:50 PM
| | Quote: |
Originally Posted by Nica Oh now who's passing who? I don't know if I would try this on my vehicles just yet but interesting question Lauren. I'm not help here babe...sorry. | aww, i thought after the volvo you would know for sure.
thanks for humoring me though. we shall see!
04-04-2007, 10:42 PM
|  | Moderator | | Join Date: Mar 2006
| | How bad off are the lenses, Lauren? Are they completely opaque? Pics would be helpful. I really like using the spot buffs on the lenses for the control they give you in getting to all the areas of the lens. If you don't want to buy the entire kit, you can buy just the backing plate for $7.99 2-3/4 Hook & Loop Backing Plate and get the polishing pal which has all the pads for $29.99 Wolfgang Polishin’ Pal is an ergonomically shaped urethane handle that holds specially designed foam pads using hooks & loops. It's 12 dollars cheaper than buying the WG lens restoration kit, but you don't get all the products so it would be your call. I think it's worth it though to get the pads. You can use your XMT polishes on the lenses. My polish choice would be determined by how badly caked the lenses are. Just my 2 cents. Good luck.
__________________ Oye como va mi ritmo bueno pa gozar |
04-05-2007, 12:16 AM
| | Quote: |
Originally Posted by FloridaNative How bad off are the lenses, Lauren? Are they completely opaque? Pics would be helpful. I really like using the spot buffs on the lenses for the control they give you in getting to all the areas of the lens. If you don't want to buy the entire kit, you can buy just the backing plate for $7.99 2-3/4 Hook & Loop Backing Plate and get the polishing pal which has all the pads for $29.99 Wolfgang Polishin’ Pal is an ergonomically shaped urethane handle that holds specially designed foam pads using hooks & loops. It's 12 dollars cheaper than buying the WG lens restoration kit, but you don't get all the products so it would be your call. I think it's worth it though to get the pads. You can use your XMT polishes on the lenses. My polish choice would be determined by how badly caked the lenses are. Just my 2 cents. Good luck.  | JEN, YOU ROCK! THANK YOU! Pictures coming up by tomorrow.
04-05-2007, 12:21 AM
| | Senior Member | | Join Date: Apr 2006 Location: Boca Raton, FL
| | | I have 4" pads but never used them on the headlights, don't think I would even if my headlights needed it. I have these man boob nipple things on them that will tear a pad apart if hit.
If you don't have nipples, try a cutting pad and light polish or even the Plastic-X which is a great product. I never used it before but last year when I had dual exhaust put on my truck, the shop was cleaning up a Jag in there and he showed me what Plastic-X and a terry cloth could do, I was pretty amazed as it took damn near mos tof the hazzing/cloudiness away. Imagine it would be pretty potent witha cutting pad.
__________________
The real WyStang: |
04-05-2007, 12:42 AM
|  | Senior Member | | Join Date: Dec 2006 Location: Central Ca. (Hwy to Sequoia)
| | | Jenn's plan sounds the best, but a "Mothers Powerball" (fits on a drill) and plastic polish will make an improvement. Read about it on the forum. |  | | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | » Popular Product Links | | | » November 2008 | | S | M | T | W | T | F | S | | 26 | 27 | 28 | 29 | 30 | 31 |
| 1 | 2 | 3 | 4 | 5 | 6 | |
