» Autogeek Car Care Products | | |  |
04-01-2007, 03:12 AM
|  | Senior Member | | Join Date: Jan 2007 Location: Chula Vista, California
| | | Carnauba: better protection from bird bombs? Is it true that carnauba provides better protection from bird bombs than sealants? If so, then why? |
04-01-2007, 05:09 AM
|  | Senior Member | | Join Date: Mar 2006
| | Quote: |
Originally Posted by klumzypinoy Is it true that carnauba provides better protection from bird bombs than sealants? If so, then why? | Yes, carnauba will give you better protection from bird bombs then most sealants. Oils in carnauba are more resistant to acids found in bird droppings.
There are a couple good sealants that are durable against bird droppings too - Klasse SG, and Duragloss #105.
__________________
1997 Acura 3.2 TL (sold)
04-01-2007, 05:12 AM
|  | Senior Member | | Join Date: Dec 2006 Location: Orlando, FL
| | Just carry a spay QD in a small 2oz bottle. When you spot the dropping, a quick spray or two and wipe. That's what I do..  |
04-01-2007, 11:30 AM
|  | Moderator | | Join Date: Mar 2006 Location: South Florida
| | | I firmly believe this is the case, but cannot give the scientific explanation. I use to get hard attacked by Zaino guys when I was a user, as each time a doo-doo hit it etched the Zaino and most times the clearcoat. This meant repolishing and sometimes wet-sanding.
When I used canaubas (mostly Pinnacle) I noticed that if is sat for several hours it still came off without markings or issue. I do now however keep a small protection kit in car so no matter what I am using, its gone quickly. |
04-01-2007, 11:43 AM
|  | Senior Member | | Join Date: Apr 2006 Location: Cobb county, GA
| | Quote: |
Originally Posted by killrwheels@autogeek I firmly believe this is the case, but cannot give the scientific explanation. I use to get hard attacked by Zaino guys when I was a user, as each time a doo-doo hit it etched the Zaino and most times the clearcoat. This meant repolishing and sometimes wet-sanding.
I do now however keep a small protection kit in car so no matter what I am using, its gone quickly. | I too carry a qd spray for the bird bombs. And killer that is wierd? I have been using zaino on my vehicle for almost 5 years. And never had any etching from the bombs?? I am trying out the DP Premium Surface Shield Paint Sealant on there now. So I will see how that holds up
__________________ Ed To achieve excellence, excellence cannot be rushed. Technique is just as important as the product used.
While my approach takes more time, the results are far superior. |
04-01-2007, 12:34 PM
| | Senior Member | | Join Date: Apr 2006 Location: Boca Raton, FL
| | | This is why I don't really use sealants anymore, and if I do I top witha wax. There were a few times that if bird took a crap and the vehicle sat out in the sun for hours, the poop was baked on and could have already left an etched mark (poop is acidic). With a carnauba, it sit all day and I can grab a hose and spray it off, that didn't happen with a sealant.
I've noticed no left over marking with a wax, compared to a sealant that would have like an outline etched in.
__________________
The real WyStang: |
04-01-2007, 12:43 PM
| | Quote: |
Originally Posted by HighEndDetail I too carry a qd spray for the bird bombs. And killer that is wierd? I have been using zaino on my vehicle for almost 5 years. And never had any etching from the bombs?? I am trying out the DP Premium Surface Shield Paint Sealant on there now. So I will see how that holds up | In all fairness, this was back in 2001 and 2002. Long before the Pro Line and CS came about. I use to use the original Z2 and always got attacked for asking why, maybe something in its makeup ?? |
04-01-2007, 02:27 PM
|  | Senior Member | | Join Date: Sep 2006 Location: New York
| | | Just have some QD with you that will help a lot nothings perfect |
04-01-2007, 02:34 PM
|  | Senior Member | | Join Date: Aug 2006 Location: Gaffney SC
| | Quote: |
Originally Posted by supercharged Yes, carnauba will give you better protection from bird bombs then most sealants. Oils in carnauba are more resistant to acids found in bird droppings.
There are a couple good sealants that are durable against bird droppings too - Klasse SG, and Duragloss #105. |
I've seen 105 hold up after a week. Best is to top your sealant with a good carnauba wax. Always have a QD in your vehicle so when you see it get it off.
__________________ |
04-01-2007, 05:14 PM
| | Thanks guys. Now it's not a myth to me anymore  . |  | | Thread Tools | | | | Display Modes | Linear Mode |
| 1 | 2 | 3 | |
