03-31-2007, 12:48 PM
| | Member | | Join Date: Sep 2006
| | | Water filtration - I'm a believer I used the AG double in-line water filtration system today and I'm a believer. First of all, maybe its my imagination but with my foam gun, using the same ratio as always (2 oz DP Extreme : 6 oz water), I was able to take the mixing valve down a notch and got even MORE thick foam. Drying was MUCH easier and in fact, my Cobra WW seemed to work like when they were new. No water spots at all. One suggestion I might make is to use a double outlet valve on the faucet with another hose so you don't have to use and/or waste filtered water when washing out your supplies. Worth the investment if you got the $$. |
03-31-2007, 03:07 PM
| | Senior Member | | Join Date: Feb 2007
| | | Thanks for sharing. I was planning on getting the water filtration system. Now I am covinced on purchasing it.
__________________ Brian |
03-31-2007, 06:12 PM
|  | Senior Member | | Join Date: Mar 2006 Location: spring hill, Fl
| | | i was given the chance to use a water deionizer a few weeks ago, and it truly left no water spots, it was amazing....i didnt need to dry the car at all. its like a 3 or 4 hundred dollar system thta hooks up to the pressure washer...im really considering getting it now because well i was skeptical before but one use and im convinced, no spots in broad daylight! |
03-31-2007, 07:40 PM
|  | Senior Member | | Join Date: Mar 2007 Location: St. Louis (South County)
03-31-2007, 08:57 PM
| | Senior Member | | Join Date: Dec 2006 Location: Orlando, FL (UCF)
| | Yup, you'll find that just about anything foams much better when water is softened
Glad to hear that, I will be picking this up... water spots are such a problem for me, even with a leafblower. With the Florida sun (or even without it), it seems that water spots already start forming a few seconds after I stop rinsing. It's so annoying. |
03-31-2007, 09:12 PM
|  | Senior Member | | Join Date: Mar 2006 Location: Killeen, Texas
| | Quote: |
Originally Posted by Kelso i was given the chance to use a water deionizer a few weeks ago, and it truly left no water spots, it was amazing....i didnt need to dry the car at all. its like a 3 or 4 hundred dollar system thta hooks up to the pressure washer...im really considering getting it now because well i was skeptical before but one use and im convinced, no spots in broad daylight! |
Kelso, do you have a link??????
I am looking to buy something NOW!!!!!!!!!!
Also, how many gallons can the filter AG sells "clean". I know it depends on the water, but I am looking for a ROUGH estimate.... Anyone?
__________________ |
03-31-2007, 10:32 PM
|  | Senior Member | | Join Date: Aug 2006 Location: Gaffney SC
| | | I want one too!
03-31-2007, 10:36 PM
| | | i was supposed to go back to the customers house tomorrow but it got postponed. i dont know the brand or anything but it was these 2 cartridge looking things secured on a cart of sorts. it had to be hooked up to a pressure washer, i dont know hwy, maybe that was just his, either way it worked amazing. ill get more info and update you cause i want one too haha |
03-31-2007, 10:45 PM
|  | Junior Member | | Join Date: Mar 2007 Location: East Bay Area-San Francisco
| | Here' the one I use...
I just spray the car down and walk away!! Absolutley NO WATER SPOTS!! Costco CR SPOTLESS De-ionized Water Filtration System CR SPOTLESS De-ionized Water Filtration System
Spot-free Rinse System;
No Drying Required $419.99
Comes with extra resin, hoses, quick-connect clamps...everything!  |
03-31-2007, 10:52 PM
| | | |  | | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | » Popular Product Links | | | » November 2008 | | S | M | T | W | T | F | S | | 26 | 27 | 28 | 29 | 30 | 31 |
| 1 | 2 | 3 | 4 | 5 | 6 | |
