02-18-2007, 06:17 PM
| | Junior Member | | Join Date: Oct 2006
| | | Need some insight before Zaino Hello all,
I have all the PB products and a PC but I still like to use zaino and I have a few questions.... - After I clay, and polish with ssr1 (very minor swirls) can I glaze then seal (EX) or should I seal then glaze.
- Can I apply zaino on top of (EX) or the glaze?
- Can I top zaino with anything (Natty's) etc..
Thanks |
02-18-2007, 07:38 PM
| | Member | | Join Date: Jan 2007
| | | I wouldnt glaze before zaino, if youre looking to glaze to fill swirls z5 pro has filling ability.
If youre dead set on using a glaze, you can put down your zaino, then put #7 on top of that, then top it with a carnauba. |
|  | Moderator | | Join Date: Mar 2006 Location: South Florida
| | | Zaino is a paint sealant, and thus needs a fresh finish. It will not adhere to waxes, glazes, nor polishes with fillers. You can however top Zaino with about anything. Some waxes like Souveran will make it look wetter and add some depth. |
02-19-2007, 05:25 AM
|  | Member | | Join Date: Jan 2007 Location: cambridge england
| | | best go with a ipa/water wipe down after polishing and then use the zaino |
02-19-2007, 10:58 AM
|  | Senior Member | | Join Date: Feb 2007 Location: Massachusetts
| | | topping zaino with a quality wax is deff the way to go imo |
02-21-2007, 08:32 AM
| | Member | | Join Date: Sep 2006
| | | killrwheels,
I was also thinking about trying some of the zaino Z5, but in reading this post I noticed you say not to use the z5 over a polish, so what should I use to clean the paint to get it ready for the z5. I was thinking polish, then z5, then top with something, but obviously this would not be the right route to take? Thanks for the help.
Sorry, just re read the post and see that it says polishes with fillers, so I take it that I do need to use a polish to clean the paint, just make sure that it does not have fillers in it, is this correct?
02-21-2007, 08:43 AM
| | Senior Member | | Join Date: Apr 2006
| | Quote: |
Sorry, just re read the post and see that it says polishes with fillers, so I take it that I do need to use a polish to clean the paint, just make sure that it does not have fillers in it, is this correct? |
What about AIO as a cleaner?? |
02-21-2007, 09:09 AM
|  | Senior Member | | Join Date: Mar 2006 Location: Mass.
| | | As Killer said Zaino needs a sterile surface to bond to..meaning no oils from polishes..you can do a wipe down after a polish and then use zaino...or you can use klasse AIO and use zaino on top...on the other forum with Zaino users..they have used AIO and topped with Zaino...
Also the EZ creme glaze from Chemical guys is a acrylic glaze with no oils and can be topped with zaino....
Also DG 921 can be used as a wipe down for Zaino...it is a cleaner and will remove polish oils....very simular to Z6..
but for best results on Zaino it has to be oil and wax free for optimum results..
the new Zaino product Clear Sealant seems to go over anything ..best to go to the Zaino page and read the Q&A section
AL |
02-21-2007, 09:24 AM
| | | QUOTE:: Also the EZ creme glaze from Chemical guys is a acrylic glaze with no oils and can be topped with zaino....
Yes a very good versatile glaze....you can top this glaze with any sealer or wax..... |
02-21-2007, 10:46 AM
| | | I've tried the new Z-AIO and Z-CS (Clear Seal)...my procedure was Z-AIO, Z5, then Z-CS back to back (no cure time necessary)...no zfx necessary. Looks great and you can optionally top the Z-CS after it cures with a carnauba or other LSP. The Z-CS is an interesting product...dries in 20-30 minutes, no buffing. |  | | | Thread Tools | | | | Display Modes | Linear Mode |
| 1 | 2 | 3 | |
