Featured Photos
by admin
531 photos
23 comments
by admin
531 photos
23 comments
by admin
531 photos
23 comments
by admin
531 photos
23 comments
» Autogeek Car Care Products
Porter Cable 7424 & Pad Kit with CCS pads!
Tags: , ,
Reply
Thread Tools Display Modes
  #1
Old 02-04-2007, 10:51 AM
Is clay use something a beginner can do?
I confess, I have never taken care of my vehicles. They have always been just transportation to me. But this year, I bought my first "nice" car, one that I actually want to take care of - A Volvo C70. Deep blue color - a real sharp looking car. So I have been researching here on the forum and have a couple of questions:
1. Clay sounds like a really good idea. Is this something that a rank amature like myself can do? I've read the tutorial and there doesn't seem like there is much to it.
2. Is there anything I have to beware of when doing it?
Any tips and pointers would be appreciated.
Thanks
  #2
Old 02-04-2007, 11:14 AM
steveo3002's Avatar
Member
yes no problems for newbies
make sure the car is freshly washed before you begin, and make sure the clay is warm ,especialy if you live somehwere cold ...warm it by kneading it until its soft
when claying the car listen and watch whats going on, check the clay and refold it often, look at it to make sure theres no big lumps of dirt picked up...listen out for scratchy noises
  #3
Old 02-04-2007, 11:21 AM
sparkie's Avatar
Welcome nebie, steveo3002 nailed it! Remember refold it often.
__________________
  #4
Old 02-04-2007, 11:25 AM
P1et's Avatar
24 HR Queue
Welcome Boomer! I'm a big Volvo fan myself, great choice on the C70! Is it the new bodystyle? Love those!
Clay is a tricky beast. In my years of detailing, I've never been able to clay a vehicle and it *not* look like it needed to be polished afterwards. I personally have used Zaino clay, which I have been disappointed by, and the Pinnacle Ultra Poly Clay, which I enjoy working with.
Make the sure vehicle is washed thoroughly before hand and use a good lube. I usually mix some Megs Gold Class with water and use that in a spraybottle as lube and it works fine.
Go slow and don't use too much pressure. Remember, clay is still an abbrasive, no matter what they tell you. I try to only go in a horizontal motion, not vertical. Left to right, not up and down.
Hope this helps!
  #5
Old 02-04-2007, 11:40 AM
Clay is one of those products that I feel anyone can use with some caution. I'd recommend using a soft clay. Although there are many substitutions for "clay lube". I'd stick with using a product that is specifically designed for clay lubrications until you feel comfortable. Although clay will take off things like bugs, tar and sap, cleaning those off before hand will keep your clay in better shape. Breaking the bar into pieces is a good idea just in case you drop it. Clean and dry the car first, use plenty of lube, work slowly and check your work as you go.
Some of my recommendations are not things I do myself. I use a soft clay on my weekly / biweekly customer cars (not every time) and a couple of more aggressive clays if required. More aggressive clays tend to marr the finish and polishing is needed. I keep my old clay for grunge work (stubborn bugs, tar and such) or heavy contaniments. I use an ONR mix for lube. I do a lot of spot claying (single panels) and often clay while washing (using ONR on most now).
  #6
Old 02-04-2007, 12:15 PM
Hope this helps!
No, it's not the convertable hardtop, those are sweet, but just a little out of my price range. I picked up an '04 that only had 7,000 mi on it! It looks like its barely seen the outside of a garage. It's almost a shame for it to become a daily driver here in Mass. But it has a nice navy blue finish that looks awesome when polished, so I figure I need to learn how to do it.
I guess I will start with some of the ultra fine clay, just to get the hang of it. And I was considering the AIO followed by the SG, Souveran, and Pinnacle Detail Spray (The Forum Favorite Kit). Any feedback on those choices would also be appreciated.
  #7
Old 02-04-2007, 12:20 PM
Nuke33's Avatar
Anyone can do it... Just go get a kit... I used the meg kid... Make sure you use plenty of lube and if you drop the clay THROW IT AWAY.... Split each little bar into 3 peices too.
  #8
Old 02-04-2007, 12:21 PM
killrwheels@autogeek's Avatar
Moderator
easy for beginner and pro alike ... allow the clay to talk to you. Cup it in your hand and glide it across the finish. When it stumbles, you need to work that area back and forth till smooth. Very easy, just remember to use alot of lubricant. Clay is not meant to grind into paint.
  #9
Old 02-04-2007, 12:25 PM
Reddwarf's Avatar
Like Killr said, use lots of lubricant. And don't drop the clay bar! It easy for a beginner. I did it early in my learning process and found it to be a very rewarding experience becuase so much grime came off on the clay bar that I was amazed. And the feel of the paint surface afterwards makes you know you accomplished something.
Good luck and keep us posted on your results.
__________________
_____________________________________
2003 Jaguar S-Type V8
2001 Nissan Quest SE
2000 Nissan Frontier XE
"Dogs in cars again. Going away. Going away fast" - P.D. Eastman, Go, Dog. Go!
  #10
Old 02-04-2007, 12:28 PM
supercharged's Avatar
Lots of lubricant, - proper lubricant. I prefer Pinnacle clay lubricant - very slick.
__________________
1997 Acura 3.2 TL (sold)
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
*Pinnacle Poly Clay Bars Jason Pinnacle Wax 15 02-27-2008 07:31 PM
Meguiars Professional Detailing Clay - Why so expensive? P1et Auto Detailing Forum 17 06-08-2007 12:11 PM
Diamondite® Glasswork Cleansing Clay sparkie New Car Care Products 16 05-06-2007 01:41 AM
Product Review: Pinnacle Ultra Poly Clay supercharged Auto Detailing Forum 7 10-11-2006 09:47 PM
New Pinnacle Ultra Poly Clay Jason Pinnacle Wax 3 04-21-2006 08:59 AM
» November 2008
262728293031 1
2 3 4 5 6 7 8
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 123456
