» Autogeek Car Care Products | | |  |
12-16-2006, 01:21 AM
|  | Senior Member | | Join Date: Oct 2006 Location: Dayton, OH
| | | Polishing Glass, how to? Has anyone ever tried using XMT series on glass?
I know AIO is a popular choice for glass, but does this always do the job?
I've noticed on many cars there are almost "etchings" of where the wiper blade wipes. Streaks that are almost imprinted in the glass. Obviously basic window cleaning doesn't take this out.
I've never tried AIO or any other polsihing on glass. I don't have my PC yet (Xmas present) so I was wandering what you all have used or done? Thanks! |
12-16-2006, 04:20 AM
|  | Senior Member | | Join Date: Mar 2006 Location: San Gabriel, CA
| | | I haven't used XMT, but SSR 1 on a finishing pad works beautifully - very quick results too. |
12-16-2006, 06:14 AM
|  | Senior Member | | Join Date: Dec 2006
| | | Polishing Glass - How-To 2. Polishing Glass (Stage Two Surface Corrosion): Once the glass surface has been washed and cleaned (detailers clay) any minor imperfections can be removed with an abrasive glass polish (Autoglym Car Class Polish or DP High Performance Glass Restorer) This thick citrus-based cream safely pulls contaminants out of the glass, including alkaline mineral deposits, and then smoothes out etched glass (http://www.autogeek.org) Be aware the some imperfections cannot be removed and you may have to replace it. If you can catch your fingernail in the scratch 0.4 Mil (0 .004 –inch deep) you should consult a professional glass repair / replacement company. A replacement windscreen can sometimes be claimed on an insurance policy without loss of no-claim bonus, dependant upon coverage (check first with insurance company). Some windscreen ‘glass’ is actually a plastic resin and will scratch easily, consult your dealer to find out what material was used for the OEM windshield. Methodology:- Clean glass to remove dirt, dust or road grime from surfaces (also see note 1)
- Apply clay (Magic Clay®) and lubricant solution (WooliteTM / Water 5:1) onto the glass surface (Do not apply to plastic as dulling may occur.)
- Apply a quarter (coin) size amount of Autoglym Car Glass Polish™ or Iz Einzette Glas Polish to a damp cutting / polishing foam pad (LC Orange or White) attached to a Porter Cable HS rotary polisher set at speed 1200 rpm.
- Heat caused by abrasive polishing can soften and damage glass; foam pad and product used must minimize heat build-up. Since glass is a poor heat conductor any friction heat built up from polishing must be kept to a minimum by using sufficient product and regular misting of both the polishing pad and glass surface with water.
- Apply to half of the windshield, polishing first in an up and down motion then in a left-to-right motion and then repeat on the other side, proceed to other glass surfaces.
- Go over the glass several times in each direction, glass will polish virtually residue free.
- Wipe off any residue, and polish with a clean dry 100% cotton Micro fibre cloth.
- Inspect glass for clarity and smoothness. Repeat if necessary.
- If the glass has PPG Industries Optech clear coating a more aggressive polish may be required
Alternative products / methods:a) Apply Zaino Z-12 with a damp cotton cloth to cool glass, apply to small sections at a time and allow to completely dry, buffing with a clean dry cotton towel. If there is any smearing or residue left just use Stoner’s Invisible Glass or any good quality glass cleaner to remove excess residue. b) Janvil Scratch Remover (JV-326 / Glass Renew JV-325) Alternative pads-these 4-inch ‘Metal Polishing Pads’ are made of course, 600 grit nylon (Scotchbrite®) and are designed for hard / rough surfaces like aluminium diamond plate, pitted aluminium, chrome, and glass. http://topoftheline.com Note:Do not use an abrasive polish on Targa ‘glass’ tops as they are actually a plastic (Lexan) and an abrasive will remove the tint Suggested product- Plexus (BTI Chemicals Plexus® Glass Polish & Cleaner) Knowledge; [ability to correctly diagnosis problems] [utilizing appropriate methods / products to solve them] |
12-16-2006, 08:37 AM
| | Senior Member | | Join Date: Apr 2006
| | Quote: |
Originally Posted by Sevenrd I haven't used XMT, but SSR 1 on a finishing pad works beautifully - very quick results too. |
I agree....good combo.....  |
12-16-2006, 08:57 AM
|  | Moderator | | Join Date: Mar 2006 Location: South Florida
| | | I have found the DP Glass Restorer to work well on stubborn marks on glass, I use a small 4 inch pad and the Pc set around 4. |
12-16-2006, 09:58 AM
| | Quote: |
Originally Posted by Whitethunder46 Has anyone ever tried using XMT series on glass?
I've never tried AIO or any other polsihing on glass. I don't have my PC yet (Xmas present) so I was wandering what you all have used or done? Thanks! | Try it! Let us know how it works.
__________________
1997 Acura 3.2 TL (sold)
|  | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | » Popular Product Links | | | » November 2008 | | S | M | T | W | T | F | S | | 26 | 27 | 28 | 29 | 30 | 31 |
| 1 | 2 | 3 | 4 | 5 | 6 | |
