10-08-2006, 10:30 AM
| | Junior Member | | Join Date: Sep 2006
10-08-2006, 10:51 AM
|  | 24 HR Queue | | Join Date: May 2006 Location: Blue Ridge GA (The Mtns.)
| | | Those are rock pits. Look at your windshield at an angle. Bet you have the same thing there. What you did when you polished with XMT is remove all waxes and dirt in the pits. This now has brought them into sight. You might want to try Megs #7 Glaze before waxing.
Remember, the PC can only correct so much. Wetsanding and a rotary may be in order next but these are for a bodyshop's professional.
Don't get discouraged. I have to even stop sometimes and say enough is enough. You can only do so much. I think the paint looks good.
As far as for 3 hours, that seems long. XMT should be used at a #5 setting for about 5 minutes in ideal conditions. I break the hood into4 sections, making sure to overlap. I time myself with a timer to make sure it all comes out evenly. So that's 20 for XMT2 and 20 for XMT1 totalling 40 minutes plus another 10 for pad clean and bottle shaking......let's make it an even hour on the hood. XMT Glaze should be used on a speed no higher than #5 on the PC. I use a #4 personally, doing the whole hood at one time. A quarter sized amount will do the hood. Takes me about 5 minutes to massage the glaze into the paint until it goes a little clear. I buff right off by hand. This gives me about an hour 15 minutes on the hood.
Hope this helps.
10-08-2006, 11:31 AM
| | | all these little dots seem more like a haze, i also have the same deal on the trunk. Its as if you spill a can of soda and it dries up looking hazy, that is what this looks like. |
10-08-2006, 11:40 AM
| | | Tape off a square area on the trunk. Buff in that area with XMT2 for 5 minutes. Remove residue and tape. Take a pic and post it. Then I can see the difference.
Like on my black 300C post. |
10-08-2006, 12:02 PM
| | | could be the polish dust filled the tiny holes (mini paint chips, pits), i dont think you'll have these on the rest of the car.
10-08-2006, 06:36 PM
|  | Senior Member | | Join Date: Aug 2006 Location: Gaffney SC
| | Quote: |
Originally Posted by justin30513 Those are rock pits. Look at your windshield at an angle. Bet you have the same thing there. What you did when you polished with XMT is remove all waxes and dirt in the pits. This now has brought them into sight. You might want to try Megs #7 Glaze before waxing.
Hope this helps. | Justin, that is some great advice. |
10-08-2006, 07:04 PM
| | Quote: |
Originally Posted by sparkie Justin, that is some great advice. | I try.
I've had to learn alot on my own and I've had fellow detailers help me out. God has blessed me with lot's of business and detailing ability. He has also gave me a place like here to share. Along with my family, all is good. Couldn't ask for more. |
10-08-2006, 08:47 PM
| | Junior Member | | Join Date: Oct 2006
| | | I have the same problem on one of my cars. It appears as though the clear coat is breaking down after polishing???? I have had this a few times and it seems polishing maginfies the problem. |
10-08-2006, 10:08 PM
| | | what did you do to fix the problem? |  | | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | » Popular Product Links | | | » January 2009 | | S | M | T | W | T | F | S | | 28 | 29 | 30 | 31 |
