10-04-2006, 11:56 AM
|  | Senior Member | | Join Date: Jul 2006 Location: Ft Lauderdale, Florida
| | | 2 Different Sealants Are there any pluses or minuses in using 2 different sealants on a car after polishing?
__________________
Darren
10-04-2006, 09:33 PM
|  | Moderator | | Join Date: Mar 2006 Location: South Florida
| | | compatibility could be the only issue. I know several that use Klasse AIO (acrylic) and Zaino (poly) together. |
10-05-2006, 05:28 AM
|  | Senior Member | | Join Date: Aug 2006 Location: Gaffney SC
| | Has anybody top AIO with Liquid Glass? Are they compatible? I'm thinking about trying that! I think Liquid Glass is acrylic too.  |
10-05-2006, 04:00 PM
| | Member | | Join Date: Oct 2006 Location: San Diego
| | I have used Klasse AIO followed by UPP four star and topped with Nattys Blue with good results.
Fred
__________________
2006 Corvette w/ Z-51, 2007 Mustang GT. |
10-05-2006, 04:37 PM
|  | Senior Member | | Join Date: Apr 2006
| | | I always use klasse sg as base coat, usually two coats, then for extra shine and depth I follow it with either DP sealant, EX-P, WG Sealant, or I skip the extra sealant and use Pinn LS, natty's, Pinn paste glanze, megs 16, or p21s, just depends on what I'm in the mood for, but I've never had any problems with any of the combos. |
10-09-2006, 04:47 PM
| | | what about using DP Sealant over NXT? Or should I just top the NXT with OCW?
__________________
Darren
10-09-2006, 05:44 PM
| | NXT is a was and so the DP couldn't go over it and I would hesitate to use NXT as a topper to a sealant either since it has kaolin clay and could probably remove the sealant. If you want to use a topper I'd go with a pure carnauba wax. Just my 2 cents.
__________________ Oye como va mi ritmo bueno pa gozar |
10-09-2006, 07:12 PM
| | Quote: |
Originally Posted by Excessive Detail I always use klasse sg as base coat, usually two coats, then for extra shine and depth I follow it with either DP sealant, EX-P, WG Sealant, or I skip the extra sealant and use Pinn LS, natty's, Pinn paste glanze, megs 16, or p21s, just depends on what I'm in the mood for, but I've never had any problems with any of the combos. |
I thought i was the only one arround using Klasse SG and Nattys/P21s!, so im not crazy.
Its a good combo, works fine over black cars but the one to beat is Klasse SG topped with Souveran  |
10-09-2006, 07:14 PM
| | | I am under the impression that the NXT is a sealant, am I wrong?
__________________
Darren
10-09-2006, 07:16 PM
| | Quote: |
Originally Posted by Darren F I am under the impression that the NXT is a sealant, am I wrong? | NXT is a sythetic wax or paint sealant. |  | | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | » Popular Product Links | | | » January 2009 | | S | M | T | W | T | F | S | | 28 | 29 | 30 | 31 |
