Featured Photos
by admin
531 photos
23 comments
by admin
531 photos
23 comments
by admin
Sema Show 2008
433 photos
6 comments
by admin
531 photos
23 comments
» Autogeek Car Care Products
Porter Cable 7424 & Pad Kit with CCS pads!
Tags: , , ,
Reply
Thread Tools Display Modes
  #1
Old 03-31-2006, 10:49 AM
Cyclo and Foam Gun Impressions
I normally don’t like to make comments on new item till I have a chance to use it a few times but the Cyclo is really impressive. I started on one fender using the PC took a couple of times with IP to clean up the finish, I did the other fender with the Cyclo and IP once and it look better then the fender done with the PC. Looking at the Cyclo it looked heavy and clumsy but it is so well balance that it is a breeze to use even on vertical panels. It also has about half the vibration of the PC and seems to glide over the finish without any effort. Also seems to use a lot less down force to get the same results. It looks like I have cut my polishing time in half at least maybe more. The PC it now on the top shelf and the Cyclo has taken it spot – the only time I will need the PC is a couple of tight spots to small for the Cyclo do.
The foam gun is a neat tool also. People that have filters like the CRSpotless will love it since you have to restrict the flow on the filters. The CRSpotless requires less that 2 gallon a minute flow rate the Gilmore Foam Guns flow at 1.5 gallons per minute. You works well with the foam part and OK with rinse but the advantage is you don’t have to use any unfiltered water in the wash.
__________________
-Dennis
  #2
Old 03-31-2006, 07:18 PM
killrwheels@autogeek's Avatar
Moderator
That Cyclo is looking like the tool to try this year ... just cannot seem to give my PC up. I tried rotary and still prefer PC considering I have only minor marring at each polish session. Thanks for the review Dennis ...
  #3
Old 03-31-2006, 10:48 PM
Neothin's Avatar
the last vette that I polished was a black C5... it had somewhat harder than average clearcoat. it took quite a bit of time to remove moderate defects. Are the new C6's painted with the same kind of clear?
  #4
Old 04-01-2006, 07:56 AM
Moderator
Quote:
yes , its funny because all detailers say the Vette clear is hard, yet the manufacturers and car chem companies all say it is soft. I find that correct polish and pad choice are all thats needed to correct minor/ moderate swirls. Now that darn orange peel, seems standard GM issue for 20 years ....
  #5
Old 04-01-2006, 09:25 AM
Neothin's Avatar
oh dont even start complaining about OP until you look at my paint! Mine is umm.... bad.
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
4-in yellow cyclo vs LC yellow Bunky Porter Cable 7424 & Buffing Pad Forum 4 08-16-2007 08:50 AM
The Edge 4 inch DoublePrecision™ Cyclo Foam Pads Meghan Cyclo Polisher and accessories 13 02-11-2007 11:45 PM
Starting my spring detailing dennish Show N' Shine 13 05-06-2006 09:41 AM
Cyclo Polisher Detail Jason Auto Detailing Forum 6 04-28-2006 04:05 PM
Mega Cyclo Polisher Kit admin New Car Care Products 13 04-21-2006 03:40 PM
» November 2008
262728293031 1
2 3 4 5 6 7 8
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 123456
