Featured Photos
by admin
Sema Show 2008
433 photos
6 comments
by Meghan
Sema Show 2008
433 photos
6 comments
by admin
531 photos
23 comments
by JDookie
Exterior Gallery
55 photos
33 comments
» Autogeek Car Care Products
Porter Cable 7424 & Pad Kit with CCS pads!
Tags: , , , ,
Reply
Thread Tools Display Modes
  #1
Old 09-22-2006, 09:36 AM
VonsWhite4x4's Avatar
ClayBar,XMT,Zaino, Wolfgang Sealant?
Hey everyone, Just Joined yesterday, however i have been lurking the site for quite some time now, im due to give my truck a complete exterior Detail. I Have some questions.
I was going to wash the truck, then clay bar it, then wash it again...simple..but with the XMT i am buyin all 3 stages of the swirl and scratch remover, i always start with the least abrasive (Spell Check) and work my way up. I am buying a High speed circular polisher and then buying edge pads as well. do you recomend using the XMT with a high speed or a DA? and what pads? meduim Cut?
Then once done with the xmt, i was gonna coat it with Z2 Pro from Zaino x2.
Then the wolfgang sealant, should i apply by hand? and i can layer that as long as i let it heal for 12 hours without touching water correct?
Thanks Alot.
Marcus
  #2
Old 09-22-2006, 09:51 AM
cwcad's Avatar
The only thing on your post that I can comment on from personal experience is the Zaino product. If you put Z2Pro on times two I would not top it with another sealant. Putting Wolfgang sealant on top of the Zaino sealant would be redundant.
What I would do it split my hood half and half and put Z2Pro on one side and Wolfgang Sealant on the other. Make yourself a test of the two products.
__________________
cwcad
Do What You Say....Say What You Do!
www.ldkbox.com a blog about life's details
  #3
Old 09-22-2006, 12:00 PM
FloridaNative's Avatar
Moderator
Thanks Alot.
Marcus
Welcome to our little family Marcus. The XMT can be used with both the DA and the rotary. I've used them with the PC and the Edge 2K pad system and had excellent results. In my experience, the XMT broke down in about 4 minutes or so and it finished very clean and with very little dust. I used the XMT 2 with the Orange Edge pad and the XMT 1 with the Blue Edge pad and after it was LSP ready. It really made the metallic flakes in my paint sparkle.
One suggestion, you could clay while you wash the truck to save some time. Just make sure you use a good wash soap.
__________________
Oye como va mi ritmo bueno pa gozar
  #4
Old 09-22-2006, 01:10 PM
For soaps i have the megs gold class wash ( Customer Vehicles ) and for my truck i use the Zaino Car wash soap...any thing particular i should look before using the clay while washing?
Marcus
  #5
Old 09-22-2006, 01:30 PM
Member
Why are you using two sealants? It will probably be best to use one or the other.
  #6
Old 09-22-2006, 09:59 PM
killrwheels@autogeek's Avatar
Moderator
As most have offered, both products work best seperately. You will find more comments on Wolfgang here naturally, as we manufacture as sell the line. Very easy to use, no mixing, and reasonable durability. It does look at little different than most sealants , not quite as sharp and reflective. Warmer ...
Zaino is still the king in durability, very glossy and reflective (pro lines). That said, others look just as nice. We found using the new DP Sealant and Z5Pro side by side look identical. We also found Duragloss to look almost exactly alike the two. So if you want durability use Zaino ... if you clean and prep often you have many choices in many colors from many vendors.
  #7
Old 09-23-2006, 11:21 AM
sparkie's Avatar
Marcus, welcome buddy. Glad you came over to check this forum out! Sparkymm6
On the XMT, it dose the work without the dusting or very little dust, then other products I've used.
I know you use a high speed buffer, so check out the Edge pads!
http://www.autogeek.net/edge-rotary-kit.html
  #8
Old 09-24-2006, 05:36 PM
JCB JCB is offline
Member
hi, im new to this addiction, may i add this, is that z2 pro or dp sealant and xmt's what you call prepping?
  #9
Old 09-24-2006, 06:14 PM
Moderator
Quote:
XMT (polish) is only one part of prepping ....
Wash --- Clay --- Polish ---- Protect
everything before PROTECT, from washing, to drying, to polishing and even claying is all the key. DP Sealant and Z2Pro are just the PROTECT feature.
  #10
Old 09-30-2006, 04:55 AM
JCB JCB is offline
Member
what is the equivalent of z2pro and z5pro in the xmt line? or can i say, can i top xmt2 after z2pro? does this make sense? sorry im just a little lost here.
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
XMT and wolfgang sealant cmarider Auto Detailing Forum 5 12-28-2007 09:14 PM
Need advise using Wolfgang Sealant Bonifax Auto Detailing Forum 9 12-01-2007 03:37 PM
Wolfgang Sealant kayakguy Auto Detailing Forum 9 10-02-2007 12:40 AM
DP sealant, wheel glaze, wolfgang gel, WOW! Kelso Show N' Shine 23 02-09-2007 08:33 PM
Wolfgang Deep Gloss Spritz Sealant On Sale matt@autogeek.net Discounts and Specials 6 01-31-2007 01:53 AM
» November 2008
262728293031 1
2 3 4 5 6 7 8
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 123456
