| Well we dont know what the finish looks like , nor shape, so :
I would start with a medium pad, and M80 with PC on speeds over 5. Continue to polish until the polish flashes well. It almost looks like talc, and Megs is a little dusty. You might need to move to a more abrasive pad for swirls, or a lower abrasive pad for finishing/gemming/jeweling the surface.
If everything goes well, remember NXT has some light filling ability. You can go to it and use a finishing pad. Speed around 3-4 on the PC. This step will be easiest and you should probably remove it with a microfiber as possible. |
