50/50 IPA calculation
Auto Detailing ForumDiscuss 50/50 IPA calculation in the Auto Detailing Forums forums; I picked up a bottle of 91% Isopropyl alcohol, (that was the only alcohol that they had), and want to ...
I picked up a bottle of 91% Isopropyl alcohol, (that was the only alcohol that they had), and want to make a mixture of 50/50. With this being higher % alcohol would I need to dilute with more water? What is the calculation? Thanks for the help.
With 70% strength isopropyl alcohol in order to obtain a 1:1 ratio (50/50 % mixture) use 2 parts alcohol to 1 part distilled water (See relevant sections for usage and dilution used.) Mix solution in a spray bottle, spray onto clean paint surface, and wipe off with a micro fibre towel.
