Featured Photos
by admin
Sema Show 2008
433 photos
13 comments
by Meghan
Sema Show 2008
433 photos
13 comments
by admin
531 photos
29 comments
by admin
Sema Show 2008
433 photos
13 comments
» Autogeek Car Care Products
Meguiars Free T-shirt
Tags: , , , ,
Reply
Thread Tools Display Modes
  #1
Old 08-08-2006, 03:01 AM
Member
Those who have used PO85RD and a few other ?'s...
Well, got my bottle in today, and the seller even included a nice size sample of 85RE5 for me to try too.
Here's what I did:
I did only the trunk, since it's all I had time for.
1. Washed the entire car
2. Cleaned the trunk with CM (no fallout, so I didn't clay)
3. Used the XMT3 for the first time. Used a light cut orange Edge 200 pad at 5 to 6 on the 7336, and it worked well. Got out almost all the swirls/scratches except the deepest ones (they aren't down to the metal, fyi). Went slowly, and worked it in about 4-5 minutes per roughly 2x2 section on the trunk.
4. Used the PO85RD with the blue Edge 2000 pad at about 1.5 on the 7336. Great stuff, left the surface very smooth and glossy looking. Again, worked it in for about the same amount of time. It appears to be everything I've read about it, and I'm very satisfied.
5. One coat of SG, WO/WO
6. One coat of NB
7. One more coat of CM for good measure.
Now, here's my questions:
1. Had some light micromarring, so should I have gone down to XMT1 with the blue pad or orange pad before I did the PO85RD?
2. For the deeper scratches, should I now go one pad more aggressive with the XMT3? If not, then what? (I have both XMT3 and XMT1)
3. Should I have used AIO somewhere in there?
4. When I did the PO85RD at speed 1.5, the pad doesn't seem to spin that much. Am I applying too much pressure? The bottle says to use "med." pressure. Should I have used the white pad instead of the blue pad?
Thanks for everyones continued help...my head is spinning from all the combinations lol
  #2
Old 08-08-2006, 03:16 AM
Neothin's Avatar
you should've used sped 6 for the 85rd. it's a polish, albeit a very fine one. it needs the speed to work properly. @ speed 1.5, it didnt do anything.
as for the deeper stuff, let it be. no use in thining your clearcoat unnecessarily.
  #3
Old 08-08-2006, 03:19 AM
Member
OK, I'll try it at that speed next time. Continue with the blue pad, or go down to the white pad (Edge 2000)?
Also, will XMT3 really remove the clear coat? I thought that they were "clear coat safe" since it really isn't a "compound" so to speak?
What about the micromarring? Go over it again with the XMT1? Or should the PO85RD take care of that?
Thanks for the help Neo.
  #4
Old 08-08-2006, 06:42 AM
killrwheels@autogeek's Avatar
Moderator
Anything abrasive can remove very small (tiny) areas of clearcoat. Thus starting with the least abrasive polish and pad first is good idea. P085 really should do most if not all the work for you. You need to use it on high (like Neo offered) and using a medium or light pad. Work it for several minutes.
Clearcoat safe = for use on vehicles with clearcoat
  #5
Old 08-08-2006, 08:16 AM
Since I had issues with my edge pads... I've talked to Aaron @ edge a few times. You really shouldn't be running the PC @ 6 very much at all. The blue pad is a finishing pad... and very soft. You can't use much, hardly any pressure with it. The white pad is even softer.
If you are using a polish you should probably be using the orange pad @ a 4 or 5. If you are needing to go to 6 or apply a lot of pressure, then from what I am told you need to be using a rotary.
  #6
Old 08-08-2006, 01:40 PM
Member
Thanks for the responses.
  #7
Old 08-08-2006, 01:53 PM
You need to work in Polishes at least at speeds 4-5 as mentioned above. Then for a final finish-up I'll go to speed 6. The PC doesn't generate the heat or power a rotary can. The Edge pads can handle speed 6 easily. Especially since I use Optimum Compound and Polish which don't break down as quick as other products.
__________________
The real WyStang:
  #8
Old 08-08-2006, 04:18 PM
Member
Quote:
Ya, I went out and re-did the trunk this morning, and there was a big difference. All the micromarring is gone, and the 85RD left a very glossy and smooth surface.
Going to do the rest of the car now....woot!!
  #9
Old 08-08-2006, 05:56 PM
I don't get it. I can't get more than two minutes out of anything. (when polishing my car, I mean).
  #10
Old 08-08-2006, 06:09 PM
Moderator
sounds like more of an excuse to use Lake Country Pads ..... never had one fall apart and speed makes no difference.
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Another Menzerna by request! Meghan New Car Care Products 29 10-12-2007 05:13 AM
Menzerna Nano Polish PO106FF vs. Final Polish PO85RD Meghan Auto Detailing University 45 10-12-2007 02:21 AM
Menzerna Final Finish PO85RD Dwayne Blog 3 10-04-2007 11:58 PM
Does anyone want to split PO85RD? FMINUS Auto Detailing Forum 1 10-04-2007 02:27 PM
Menz PO85RD joe.p Auto Detailing Forum 15 05-24-2007 10:40 PM
» January 2009
28293031 1 2 3
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
