» Autogeek Car Care Products | | |  |
09-19-2008, 04:58 PM
|  | Senior Member | | Join Date: May 2007 Location: Welland, Ontario
| | | Would you try this stuff?? I work in a machining shop that makes valve body parts for GM. We use an industrial cleaner caller Parco MP 310 as a detergent in our parts washer. I would say around 100:1 and it rinses off the light machine oil as the parts come through a big industrial parts washer on a conveyor. Checking the WHMIS data sheet it says ph of 12.5. We are selling an old machine and the gentleman was cleaning 20 yrs plus worth of grease and oil that were caked on this unit. I asked him what degreaser he was using and you guessed it. Our trusty parts washer soap. Mixed stronger of course but he said it cleaned like no ones business. Now I would never let this stuff near my paint but I am considering trying it as an engine cleaner on my old Chrysler van. Anyone got any ideas why I shouldn't give it a shot??
Pat.
__________________
2006 Black Rav4.
Makita 9227C, UDM, Optimum polishes,Menzerna Power Finish, Pinnacle XMT polishes, Poorboy's Sealant, Collnite Insulator wax, various 4,6.5,and 8 inch CCS pads. Edge pads. Microfiber towels galore. And a big thanks to Meghan for shipping to Walt Disney World.
09-19-2008, 09:11 PM
| | Senior Member | | Join Date: Feb 2008
| | | Re: Would you try this stuff?? I would worry about it on aluminum parts... |
09-19-2008, 11:16 PM
| | | Re: Would you try this stuff?? 80% of the material being washed is aluminum.Granted the soap is very diluted but why should I be concerned with aluminum? The ph level?
Pat.
__________________
2006 Black Rav4.
09-20-2008, 01:26 AM
| | | Re: Would you try this stuff?? If it is used on polished aluminum like what is under the hood of a car without a problem then nevermind. I didn't read your description of what it was used on very well. Just remember that dilution ratios can change ph dramaticly in some chemicals so be careful. |
09-20-2008, 08:17 AM
|  | Moderator | | Join Date: Mar 2006 Location: South Florida
| | | Re: Would you try this stuff?? I find a good APC is all thats needed to clean an engine compartment. I run the engine for a little heat, spray, agitate, and spray. I worry alot about these stronger products damaging parts and how caustic they are to me when heated. |
09-20-2008, 01:45 PM
|  | Senior Member | | Join Date: Dec 2006 Location: Central Ca. (Hwy to Sequoia)
| | | Re: Would you try this stuff?? There is all kinds of paint in your engine bay. 12.5 ph is fairly caustic (7 being neutral). I'd also be concerned with what it does to hoses, belts, wiring. Might get by with it with an immediate rinse, but I'd go with what killr says. |
09-20-2008, 04:27 PM
| | | Re: Would you try this stuff?? Tried it a last night. Mixed about 10:1. Loose greasy dirt came right off as it was hit with the sprayer. Plastic containers like brake fluid, coolant, and WWF clean as a whistle. Also removed lots of stuff from the paint around the shock towers. Motor was still fairly warm so I didn't let the stuff sit, I will try again with cold motor.
Pat.
__________________
2006 Black Rav4.
09-20-2008, 05:10 PM
| | | Re: Would you try this stuff?? Did you notice any corrosion or discoloration when dry? |
09-20-2008, 11:04 PM
| | | Re: Would you try this stuff?? I didn't notice any discoloration. I will look closely tomorrow in the daylight. Great cleaner, I just hope it doesn't hurt anything.
Pat.
__________________
2006 Black Rav4.
|  | Member | | Join Date: Sep 2008 Location: San Diego
| | | Re: Would you try this stuff?? The Main thing I would worry about is such a strong cleaner drying out your belts, hoses and plastic electrical connections.
Good luck. |  | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | » Popular Product Links | | | » January 2009 | | S | M | T | W | T | F | S | | 28 | 29 | 30 | 31 |
