Featured Photos
by admin
Exterior Gallery
55 photos
33 comments
by admin
Sema Show 2008
433 photos
6 comments
by elkphoto
Exterior Gallery
55 photos
33 comments
by admin
531 photos
23 comments
» Autogeek Car Care Products
Covercraft
Tags: , , ,
Reply
Thread Tools Display Modes
  #1
Old 08-07-2006, 10:21 AM
Sn95nik's Avatar
Member
Durability Experiment -> Cloudy Hood?
Hello all,
I'll be brief, but I'd like some feedback on a problem I had this weekend. I hit the hood of my Laser Red Mustang with SSR1, and then layed down three different LSP's in different areas with the idea of doing a durability test. The products were Meg's #26, DP MaxWax (love the way this went on and off!), and Duragloss 601/105 combo. Now I know I don't have any , but it started to rain not long after I noticed the problem, so I'll just describe it as best I can. Basically, the paint looks cloudy across the entire hood. Like some areas of the paint are much darker than others, in random blotches, no real pattern to it. Since this is spread across the entire hood, and not just one of the LSP's, I'm assuming it must be something to do with the SSR1. Is it possible that the oils in SSR1 could cause cloudy paint if not removed before LSP application? Would an IPA wipe-down after polishing have helped this? TIA for your help,
Nick
PS. So much for being brief, I apologize, but I'm just a little frustrated
  #2
Old 08-07-2006, 12:44 PM
Excessive Detail's Avatar
Correct me if I'm wrong, but max wax and #26 are nuba pastse, and I don't know about duragloss, and pastse aren't really meant to hold up to long, usually through a few washes, if that. Probably waht going on is you didn't remove all the product to layed down, either when you were polishing or usinf lsp. I would take your qd and a fresh mf and wipe down the area. Also, you may not have layed down the lsp evenly, since you used three different ones, and with most nubas its good to use a foam app. pad to evenly thin out the nuba.
  #3
Old 08-07-2006, 01:23 PM
Sn95nik's Avatar
Member
Quote:
You're correct, the MaxWax and the #26 are both Carnuba's. The Duragloss is a synthetic, but I was really more interested in which carnuba would last longest. I'll be using the Duragloss over the winter months, and just wanted to get an idea of how long it will last with proper care. Let me point out again that I did not apply all three products on top of each other, they are in adjacent areas next to each other. All were applied thinly with foam apps. I too though that perhaps I had not removed all of the product, or didn't lay them down evenly, but I have the same haziness/cloudiness under all three LSP's. This is what led me to believe it was an issue with the SSR1, because that is the only thing all three areas have in common. I'll make sure and try an IPA wipe after the SSR next time, to see if I can confirm this. Thanks.
  #4
Old 08-07-2006, 01:33 PM
wytstang's Avatar
Quote:
#26 is a synthetic blend isn't it???
__________________
Surfer Caught on tape
  #5
Old 08-07-2006, 02:48 PM
Sn95nik's Avatar
Member
Quote:
The extent of my knowledge on #26 is that it contains Carnuba. I won't claim to be an expert, because I'm not. There is a very good chance it could contain synthetics as well.
Either way, this still wouldn't change the fact that the cloudiness I've seen covers the whole hood, under all three different areas with all three different LSP's. The ONLY product that was used in all three areas is the SSR1. I'm currently at work, but I'm going to try to wipedown the hood with QD when I get home, and see if the I can get some pics of this to show you guys. After that, the next step will, I guess, be an IPA wipe down and re-application of the LSP's to see if the haze/cloudiness comes back.
  #6
Old 08-07-2006, 05:43 PM
killrwheels@autogeek's Avatar
Moderator
cloudiness is normal one of two items. A sealant that did not properly cure (toss that one out although Duragloss is a sealant) or the polish did not break down completely at left high/low spots. Thats why I always suggest an alcohol wipe down before ANY protectant.
Try to wipe the car with some distilled water and see if its gone. It could also be too much product, but highly unlikely since you used three different brands.
  #7
Old 08-07-2006, 06:05 PM
Agree, I don't think you broke down SSR enough, try using IA or Klasse AIO then follow up with your products. Especially since all 3 brands showed the same character.
__________________
The real WyStang:
  #8
Old 08-07-2006, 06:18 PM
supercharged's Avatar
I always wipe down the surface with 50/50 water/rubbing alcohol BEFORE applying any sealant. Same should go for wax too. And if you know it's gonna rain soon, park under a shelter or in a garage.
__________________
1997 Acura 3.2 TL (sold)
  #9
Old 08-07-2006, 06:38 PM
Reddwarf's Avatar
This is interesting. I had not picked up on the alcohol wipe down before. So, Killr, is suggesting that after he removed the PB SSR1, he should have wiped the car down with isopropyl alcohol. I assume with an MF? Supercharged suggests a solution of 50/50 water and alcohol. Then Surfer mentioned AIO. Hmm, a little more details here would be good – for Sn95nik and some of us other folks too!
__________________
_____________________________________
2003 Jaguar S-Type V8
2001 Nissan Quest SE
2000 Nissan Frontier XE
"Dogs in cars again. Going away. Going away fast" - P.D. Eastman, Go, Dog. Go!
  #10
Old 08-07-2006, 06:55 PM
Moderator
AIO is paint cleaner with no real fillers, so a perfect starting place for adding any protectant (wax or sealant).
I rub down with alcohol (alcohol is already a combination w/ water) for two reasons. Removes any missed polish, it removes any fillers, and gives a pristine finish for ANY protectant to adhere too. It also shows me if any of the swirls or marring was just hidden (by fillers) versus truly removed. That way I can go back to a polish again and again if necessary.
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Protecting CF hood from Florida sunshine? CSOCSO Auto Detailing Forum 6 12-17-2007 09:39 PM
Polished hood but not happy CLL Show N' Shine 11 10-12-2007 05:42 PM
Swirls on Hood Only???? P8ntballer597 Auto Detailing Forum 5 05-03-2007 11:42 PM
Mazda5 hood vs. German Shepherd Sevenrd Show N' Shine 5 12-17-2006 01:17 PM
Help for Black Accord hood alban61 Auto Detailing University 9 09-12-2006 05:28 PM
» November 2008
262728293031 1
2 3 4 5 6 7 8
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 123456
