Quote:
Originally Posted by killrwheels@autogeek single stage paint with transfer paint and oxidation to polishing pads. All you can do is wash them well to try and remove it. Likely the pads may have some light staining if not removed immediately but still can be used. |
Thanks thats what I figured.. I let the pads soak over night in two gallons with the pinnacle micro rejuvinator. I did well on breaking down the chemical, but the pad is stained. The orange pad is stained worse then the yellow.
