Need advice... new white car
Auto Detailing ForumDiscuss Need advice... new white car in the Auto Detailing Forums forums; I could use some feedback from veterans here on how to best protect the paint on a new white car.
As I mentioned the car is white and will be parked outside 99% of the time. My #1 priority is to protect the paint but a close second is to achieve as wet a look as possible with white. Please offer any suggestions or advice.
Here's my plan but I'm not sure if this is appropriate given its a new car:
1) Wash
2) Clay bar
3) Wash
4) Apply DG 601 with 7424 (blue pad)
5) Apply DG 105 with 7424 (blue pad)
6) Buff with wool pad covered with microfiber bonnet
Questions: How long do I need to wait between steps #4 and #5
As I mentioned before, please let me know if I've missed a small step somewhere in the process. Thanks!!
Is DG601 like the old Zaino prep agent where you place sealant directly over it, or is it buffed off first ?? (I cannot remember) I dont remember any appreciable wait time needed with these booster type products however.
I believe you place the 105 directly over the 601. I guess the concept is similar to a 2-part epoxy. But I'm not sure...
You put 105 over 601 WITHOUT removing 601 first. Cover the whole car with 601 and then go back and do the same panel order with 105. That will give 601 just enough time to flash and be ready to accept 105 on each panel.
You will love that combo.
__________________ What if the Hokey Pokey IS what it's all about???
67Customs...
What about my application method and pad chioce? Thanks.
Now if was me..i would do 501 with a white pad first..to deep clean the white paint....there are posts here where some used 501 on white and it just brought the white to a new level of brightness.....and then by hand do 601...cover paint completely with a thin coat..let haze up a few minutes...then by hand again do 105....right over the hazed 601..do not remove the 601...the residue acts like a hardner to the sealant.....then remove the combo after about 30 minutes of hazing up....a day later do a wipe of AW after a wash....dry the car..spray AW on a panel...1 spray does it..and wipe it in....buff after with a dry MF..your done ...do AW monthly to keep the paint super slick
I really appreciate all the good information here...
It it everyone's opinion that this combination (501...601...105...AW) is the best protection to offer a car that's ALWAYS outside?
A couple questions for everyone:
1) my driving is pretty light and in the southeast where there's little snow each winter. How often should I apply the 501, 601 and 105 combination? Obviously I'll apply AW after most washes.
2) A white pad seems aggressive considering the car is brand new. I'll use it if everyone agrees that the thing to do I was just curious why a relatively agressive pad was needed for new paint.
