Featured Photos
by admin
531 photos
29 comments
by admin
Sema Show 2008
433 photos
13 comments
by admin
531 photos
29 comments
by admin
531 photos
29 comments
» Autogeek Car Care Products
Ice Master Multi Blade ice scraper
Tags: , , , , ,
Reply
Thread Tools Display Modes
  #1
Old 08-03-2006, 01:34 AM
Member
Cut amount of pad versus cleaning agent
I've read a good deal both here and on two other forums, but I have a question that I didn't really seem to find the answer to.
Is going with a higher (more cut) cleaning agent with a polishing pad that has less cut to it the same as going with a lighter cutting agent with a higher cut pad?
Say for instance, is using something like XMT 3 with a orange or blue Edge pad the same as using XMT 1 with say a green pad?
I seem to have removed about 80% of the scratches in my clearcoat using ## Revive (I had this prior to ordering my XMT, which still hasn't come in yet argh) and an orange light cut Edge pad. So, I guess I'm wondering what my next step is....use the XMT 3 and the orange pad, or try the blue pad first?
My order should come in tomorrow (according to Monique), so I'm trying to get my plan of attack together
  #2
Old 08-03-2006, 05:52 AM
Racer Dude's Avatar
The XMT 3 is not a heavy compound. I would at least start with the orange light cutting pad if not the yellow pad. What you don't get out with the orange or yellow pad with the XMT 3, you can hide with the finishing glaze.
  #3
Old 08-03-2006, 07:23 AM
killrwheels@autogeek's Avatar
Moderator
I always start with the white (Lake Country) middle ground polishing pad. I usually start with a moderate polish. I then increase to a heavier polish first as needed, before going to a more abrasive pad. Orange and yellow pads seem to always leave some haze and micromarring, and with white pads and 2.5 SSR, or Menzerna, I sometimes escape. Then I can jump to "jeweling" quite quickly with a finishing pad and polish.
If you start with Orange pad, you will likely need to do two additional steps to properly polish. Moving back to white with same or lower polish, and then onto the finishing pad and finishing polish.
  #4
Old 08-03-2006, 02:25 PM
Member
Killr
What is equivalent to the white LC pad in the Edge line? The blue?
As soon as my XMT gets here, should I start with the blue edge pad and the XMT 3? I don't believe that the XMT 1 will remove some of the scratches I have (at least the ## revive with an orange Edge light cut pad didn't).
When I'm satisfied with the finish, I'll move on to the PO85RD, and should I use the blue again, or go down to the white Edge pad?
Thanks for all the help BTW.
  #5
Old 08-03-2006, 07:21 PM
Moderator
While the P085 will likely due what you want initially, I would start with XMT 2 first. Moving to 3 only as needed. High speed, take your time, and use some pressure. I believe the medium grade polishing pad by Edge is Orange ... the blue is the finishing pad. Correct ??
  #6
Old 08-03-2006, 07:31 PM
Quote:
On my Edge packages, looks like the white is the finishing pad, and the blue is a step below. Edge Cutting pads go from Orange -> Green -> Yellow in terms of cutting ability.
__________________
The real WyStang:
  #7
Old 08-03-2006, 08:38 PM
Member
Killr,
Like Surfer said, the Edge system goes like this, from least to most cutting ability:
White
Blue
Orange
Green
Yellow
That being said, I didn't get the XMT2, only the 1 and 3 in the package on AG. So, can I go with the 3 and use a pad with less cut since I don't have the 2?
Thanks again.
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
New Technique- Pad cleaning budman3 Porter Cable 7424 & Buffing Pad Forum 36 03-29-2008 06:51 PM
Cleaning LC Pad AjNavo61490 Auto Detailing Forum 5 11-15-2007 08:57 AM
Newbie ? about PC use and pad cleaning Hootie Auto Detailing Forum 0 06-12-2007 12:17 PM
2007 Pontiac G5 Nica Show N' Shine 36 05-27-2007 11:23 PM
Edge 2000 4" Pads - PRODUCT REVIEW MikeyC Auto Detailing Tools and Accessories 12 11-15-2006 06:59 PM
» January 2009
28293031 1 2 3
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
