Quote:
Originally Posted by killrwheels@autogeek A polishing pad attached to a backing plate like the 7424 or a seperate backing plate for polishing ??  |
Technically, it's the 7336sp. It comes with a 6 inch counterweight and has the pictured attachments. Both sanding pad and polishing pad come with with their own spindles for direct attachment to the PC.
I would've prefer the standard velcro sandpaper backing pad. I wouldn't have had to buy a backing plate then. The sanding pad it comes with is designed to be used with self-adhesive sandpaper. Almost every other manufacturer ships their sanders with a velcro pad.
