Featured Photos
by admin
531 photos
29 comments
by admin
Before & After
13 photos
3 comments
by Meghan
Sema Show 2008
433 photos
13 comments
by admin
Sema Show 2008
433 photos
13 comments
» Autogeek Car Care Products
Ice Master Multi Blade ice scraper
Reply
Thread Tools Display Modes
  #1
Old 07-16-2008, 11:32 AM
Keith Harrison's Avatar
Noobie questions
Gents, (and ladies)
1st let me say I appreciate the wealth of information on this forum. Its informative but to a noobie a bit overwhelming. I've tried to answer all my questions without a post but have a few questions left so here goes.
I just purchased an 06 Boxster S. Lapis Blue. Has 3k miles on it and basically brand new in appearance. When i drove it off the lot I was so pleased with the exterior appearance of the car that I immediately started searching the internet for products to maintain it which lead me here. So far i have purchased for the exterior:
> P21S Carn. starter kit: Includes Tire Gel, Shampoo, Paintwork Cleanser, 100% Carn. Wax, var. applicators...
> Cobra Start Kit:Ultimate Guzzler, Wash Mitt, Applicator Pads, Polishing Cloths
> I also have some Meg. (Gold I think) Quick Det. left from my previous adventures which I use limitedly almost daily. When it runs out I'll be changing.
> Meg. Tire Gel from previous car.
So last weekend was my first serious (to me anyway) detail. I did all wash work in shade.(6:30am shade. Been a long time since I cared enough for a car to get up at that time to clean it!)
Went through the normal steps as you would expect from my purchases:
1. Soaked/cleaned tires with Gel
2. Rinsed entire car with water
3. Washed with MF Mitt and shampoo
4. Dried with Guzzler
5. Polished with Paint Cleaner with supplied sponge
6. Waxed with 100% Carn. / MF
7. Dressed tires
Car looked awesome in my garage. It was the most fulfilling cleanup in my history. I've had other nice cars but sadly never really maintained them properly.
Anyway, I of course started to closely look at the paint in the direct sunlight and noticed spider webbing I guess you call it. Circular reflections around the direct sun light. I also noticed a few light scratches i had never really noticed. I would hope that as careful as I was it was not a result of my cleaning efforts but me revealing what was already there.
So here comes the questions finally!
I know missing in my arsenal is a DA polisher. I'm contemplating the Flex and I've read all the chains telling that I need one. I got it!!
In the meantime, is there anything I can do by hand to remove these? Also, in the normal course of washing/waxing with the above steps should I expect to add scratches/swirls as just the "nature of the beast"?
Next, I'm a little confused/afraid by the Flex. Within the steps I took this weekend, how many steps would I be adding and where would they go?
Would I use Paint Cleaner first to clean the surface and then run Flex or Flex then clean, then wax?
Also, assuming minor webbing/scratching how many times would I need to go over the car with the flex? I've read about the various pads etc and I'm wondering if I start with minor scratches and remove them is that a 1 step, 2 step, etc
Finally, using the flex no doubt introduces abrasion. Over a long enough time this would have to ultimately cause damage I would assume. So the question is, how often do you recommend a full polish like this? I know a simple answer is when needed but I guess this goes back to my previous question about what to expect from normal washing/waxing.
I fully expect to wash my car at least once a week. I would expect with Carn. wax to probably use the cleaner/wax at least once a month.
In this regimen, where does Flex/Polishing fit in? Do you polish every waxing? Twice a year? etc.
2 other real quick questions:
1. I had some light overspray from something and I ultimately used GoofOff to remove it. It worked great and I have seen no reprocussions so far. Any thoughts on that? I noticed a few threads about over spray.
2. I have an odd spot on my hood that looks like maybe tree sap or something. It feels smooth to the touch but will not come off. I was hoping the P21s Cleanser would get it but no luck. Also, GoofOff did not work. Will Flex process remove that or do you have any other suggestions?
As you might expect, my ultimate fear in all of this damaging my babies skin!
Thanks a bunch for feedback and all that you guys do to help us amateurs out!
  #2
Old 07-16-2008, 12:03 PM
ASPHALT ROCKET's Avatar
Re: Noobie questions
Welcome Keith-as far as the swirl marks it was probably from the place you bought it from, must have had a bunch of filler in ti to make the paint look like it did. When you washed it all the filler was removed. Also when washing are you using the two bucket method and I would sheet the water before drying so there is less water on the vehicle and no need to over dry it to induce those little swirls. The paint cleaner would probably hide the swirls by hand but it would be a very good idea to purchase a PC or Flex. The flex or pc are not going to hurt the finish over time unless somehow the side of an aggressive pad came in contact with your paint. I would get atleast 3 of the orange, green, white, blue, and black/gray pads. Pick up some Menzerna sip and 106FF/85RD or the new Wolfgang polishes. Use them with a green pad then follow up with a finishing pad-blue or gray and that should get rid of the swirls and then you can go to your lsp. If I missed something let me know and I reply to that also.
  #3
Old 07-16-2008, 01:14 PM
Thanks for the quick response. I did not use the 2 bucket method but did read about it last night and will incorporate into my routine. Makes sense... Forgive me but what is LSP? By sheeting do you mean just drag a towel or something over the car to drag most water off, then dry lightly? That is pretty much what I did. I tried to go back in one of the more noticable spots on the rear hood with the P21 cleaner but it really didn't seem to affect the swirls all that much. Maybe a tiny bit. Might do more with a flex.
I assume SIP is Super Intensive Polish. There is a new 106FA. Would you stick with FF or buy the new one?
So in most cases it sounds like a 2 step process SIP w/ either OR/Green/Wh depending on condition and then 106FF or FA with Blue/Gray?
If doing this polishing, is there any need for the P21S cleanser in the mix? If yes, before or after above polishing?
Finally, any thought on the 2 quick questions?
Many thanks!
  #4
Old 07-16-2008, 01:22 PM
2 more ? How many uses do you typically get out of a pad? And, do you normally polish every time you wax or do you wash/wax and only polish when needed?
  #5
Old 07-16-2008, 02:25 PM
redg35's Avatar
Many thanks!
LSP stands for last step process which means either a wax or sealent is next.Sheeting means just using the garden hose flow water on all parts of the car and the water will come off in sheets making it much easier to dry.
When you are using a ploish there is no need for a paint cleanser.
__________________
No more supercharger,i now have twin turbo,s.
  #6
redg35's Avatar
Pads will last a pretty long time if taken care of and you only want to polish when needed.
__________________
  #7
Old 07-16-2008, 03:15 PM
Redsg35 pretty much answered your questions. I like the ff a little better, less working time. And yes following up with finishing polish on a finishing pad is key and will make a difference. I always like to use a paint cleaner after a wash and then lsp. I am not into using quick detailer sprays, only for clay lube.
  #8
Old 07-16-2008, 10:25 PM
Thanks all. OK so I am committed now to the Flex. Thoughts on pads? Should I just get the $469 Menz kit? Any major differences in the brand of pad that I should be aware of?
  #9
Old 07-16-2008, 10:38 PM
I prefer the LC pads, had alot of problems with the Edge pads, plus if you get the Menzerna kit the LC pads actually work better with it than the Edge pads.
  #10
Old 07-16-2008, 10:50 PM
Great Thx. Sorta figured since the LC's came in the kit they might be preferred but didn't want to assume.
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Winter AIO and ONR questions muddy Auto Detailing Forum 16 11-13-2007 01:33 PM
Questions about XMT 360 brig2221 Auto Detailing Forum 4 05-21-2007 08:54 PM
placing my first order but have questions about products shevie Auto Detailing Forum 5 10-03-2006 06:23 PM
first detail questions! little nervous! Co0lDood Auto Detailing Forum 11 07-24-2006 02:34 PM
Questions? Excessive Detail Auto Detailing Forum 2 05-25-2006 11:51 PM
» January 2009
28293031 1 2 3
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
