Go Back   Auto Geek Car Care, Car Wax and Auto Detailing Forum > Auto Detailing Forums > Auto Detailing Forum
Featured Photos
by admin
531 photos
6 comments
by admin
531 photos
6 comments
by admin
531 photos
6 comments
by admin
531 photos
6 comments
» Autogeek Car Care Products
Lake Country Buffing Pads
Reply
Thread Tools Display Modes
  #1
Old 06-28-2008, 02:23 AM
SweetJazz's Avatar
Member
How to stop Menz Nano (PO106ff) from dusting?
I'm in the middle of detailing my car but half my time is being spent cleaning up all of the dust left by the Menz Nano Polish (PO106ff). I'm using the Flex DA with a white LC CCS white pad. I'm very happy with the results so far. However, is there a product mix or technique to prevent the dusting? I live in Northern CA where the weather is warm with low humidity.
  #2
Old 06-28-2008, 02:54 AM
Re: How to stop Menz Nano (PO106ff) from dusting?
It dust quite frequently when I use it as well with my UDM (I live in Reno, NV). I've read it doesn't dust as bad when you use it with a rotary, but it does still dust. I believe it's just the nature of the beast. You can pick up a California Car duster to remove the dust, but to be honest I just continue polishing and then wash the car after I'm done with my final polishing/glazing stage.
__________________
2003 Lancer Evolution VIII
Buschur TBE, Apex'i intake, Hallman Pro RX MBC, Evo 9 and Forge DV's, Swift Sport Machs, FP Green, ETS 3.5 FMIC and piping, Megan coated mani, Megan O2 housing,injectors, Walbro 255, HKS 272's, ARP headstuds, and Cosworth headgasket
272 AWHP (DynoDynamics, 312AWHP DynoJet) 93 oct
252 AWHP (DynoDynamics, 292AWHP Dynojet) 91 oct
^^^Old numbers
  #3
Old 06-28-2008, 07:14 AM
killrwheels@autogeek's Avatar
Moderator
just blow it off or rewash when done, make sure you are not using to much and caking the pads.
  #4
Old 06-28-2008, 09:34 AM
Bri Bri is offline
Member
how much is too much? I try to use 2-3 pea sized dots and it seems like it's not enough. The polish doesn't spread like how blkyukon's video does (before turning the polisher on).
__________________
Club Flex
  #5
Old 06-28-2008, 10:17 AM
try a light mist of water or pad conditioner before each 2x2 section.
__________________
AJ Auto Detail, LLC
  #6
Old 06-28-2008, 10:26 AM
Wink Re: How to stop Menz Nano (PO106ff) from dusting?
Thats what I do,spritz it with a little water.
Only time I had it dust or gum up was when I hit an area exposed to sunlight. (don't have a garage)
  #7
Old 06-28-2008, 02:49 PM
mixxer's Avatar
A little dot of optimum will help also.
__________________
Detailed Reflections
  #8
Old 06-28-2008, 04:17 PM
Rsurfer's Avatar
Quote:
a litle dap of OP will give you more working time and cut down the dusting.
  #9
Old 06-29-2008, 12:29 PM
SweetJazz's Avatar
Member
Quote:
Two dots of Nano and one dot of OP. I will try it next time.
  #10
Old 06-29-2008, 03:13 PM
Rsurfer's Avatar
Quote:
You may need two nickel size of 106 and 1 dime size of OP to prime the pad. After the first section you can reduce to 2 pea size per section.
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Did AG stop carrying SC Glass Cleaner? Bunky Auto Detailing University 5 05-27-2008 09:32 AM
Menzerna IP dusting mliebs8 Auto Detailing Forum 12 07-19-2007 07:29 AM
Xtreme pad dusting what gives??? AUdakota Auto Detailing Forum 12 06-19-2007 12:05 PM
When does it stop? Gnarboots11 Off-Topic 19 06-15-2007 10:03 AM
Stop it AG! Please Stop! Black Diamond Auto Detailing Forum 19 05-24-2007 09:57 PM
» August 2008
2728293031 1 2
3 4 5 6 7 8 9
10 11 12 13 14 15 16
17 18 19 20 21 22 23
24 25 26 27 28 29 30
31 123456
