06-20-2008, 05:12 AM
|  | Senior Member | | Join Date: Dec 2006
| | | Re: Circles or Straight Lines? Polish /Wax / Polymer Directional Application: What makes a scratch visible is the way light reflects from its microscopic peaks and valley’s are two-dimensional and the light reflects from them differently from the rest of the paint surface. The reasoning behind hand polishing in one direction only is that unlike a machine polisher the pressure applied is not consistent, especially if you polish using circular motions. The inconsistent abraded pattern causes light to reflect unevenly thereby highlighting the abrasions or scratches Order of product application- hood- roof-trunk from front to back and, where practical, the quarter panels- door panels- and bumpers from top to bottom. Washing, claying and waxing that way has to do with the way light reflects off the body panels and is also less likely to show the surface marring that you will invariably make.
• Polishes- these products contain abrasives and should be applied in straight-line motions (Forget what Mr. Miyagi was teaching the Karate Kid) circular motions will cause circular directional marks (swirl marks) When an abrasive is applied by hand the pressure applied is uneven and the reflected light highlights the peaks and valleys differently. •Polymer sealant, Glaze or Wax- these products are all non-abrasive so direction of application won’t cause directional marks to the surface. •Machine application - when you abrade an area with a machine and a foam pad these abrasions form a uniform pattern (the machine /foam pad applies an even and consistent pressure) and light reflects from its surface evenly without any two-dimensional reflectance. •Optimising light refraction - apply product in ‘direction of airflow’, horizontal surfaces hood to trunk, vertical surfaces front to back. This application technique affects the paints optical properties by optimising the surface light refraction and the reflectivity of the bodylines and contours of the vehicle |
06-20-2008, 01:16 PM
| | Junior Member | | Join Date: Jun 2008 Location: British Columbia, Canada
| | | Re: Circles or Straight Lines? Quote:
Originally Posted by TOGWT Polish /Wax / Polymer Directional Application: What makes a scratch visible is the way light reflects from its microscopic peaks and valley’s are two-dimensional and the light reflects from them differently from the rest of the paint surface. The reasoning behind hand polishing in one direction only is that unlike a machine polisher the pressure applied is not consistent, especially if you polish using circular motions. The inconsistent abraded pattern causes light to reflect unevenly thereby highlighting the abrasions or scratches Order of product application- hood- roof-trunk from front to back and, where practical, the quarter panels- door panels- and bumpers from top to bottom. Washing, claying and waxing that way has to do with the way light reflects off the body panels and is also less likely to show the surface marring that you will invariably make. • Polishes- these products contain abrasives and should be applied in straight-line motions (Forget what Mr. Miyagi was teaching the Karate Kid) circular motions will cause circular directional marks (swirl marks) When an abrasive is applied by hand the pressure applied is uneven and the reflected light highlights the peaks and valleys differently. •Polymer sealant, Glaze or Wax- these products are all non-abrasive so direction of application won’t cause directional marks to the surface. •Machine application - when you abrade an area with a machine and a foam pad these abrasions form a uniform pattern (the machine /foam pad applies an even and consistent pressure) and light reflects from its surface evenly without any two-dimensional reflectance. •Optimising light refraction - apply product in ‘direction of airflow’, horizontal surfaces hood to trunk, vertical surfaces front to back. This application technique affects the paints optical properties by optimising the surface light refraction and the reflectivity of the bodylines and contours of the vehicle | Great post, thanks for the info! I am starting to bring things together now...  |
06-20-2008, 01:21 PM
|  | Senior Member | | Join Date: Apr 2006 Location: Summerville,SC
| | | Re: Circles or Straight Lines? Listen to TOGWT he's forgot more then most of us know  heck if I knew half of what he's forgotten I'd be going places lol.
__________________ Surfer Caught on tape
Surfer after months of icing down your........how do you feel?  |
06-20-2008, 02:41 PM
Originally Posted by TOGWT •Optimising light refraction - apply product in ‘direction of airflow’, horizontal surfaces hood to trunk, vertical surfaces front to back. This application technique affects the paints optical properties by optimising the surface light refraction and the reflectivity of the bodylines and contours of the vehicle | May I ask which laws of physics (optics) would stand behind this? |
06-20-2008, 03:17 PM
| | Senior Member | | Join Date: Apr 2006 Location: Boca Raton, FL
| | | Re: Circles or Straight Lines? I kinda do half circles/circles, works better then straight for me. But I haven't used wax in awhile as I have no time, barely wash the vehicles right now, if I do use anything its AW which is buff on buff off.
__________________
The real WyStang: |
06-20-2008, 03:26 PM
| | Senior Member | | Join Date: Mar 2006
Originally Posted by Al-53 the theory is that straight line application reduces the chance of swirling and also it is suppose to reflect the light better if done in straight line....some sealants even say do in straight lines for the best looks...
the process is...top panels..roof...hood...trunk area do as the wind flows..front to rear...
side panels..do as the rain falls..top to bottom....
AL | I'm with Al. I started to use this method when applying paste wax. With sealants, and liquid waxes, I use circular motion since there is hardly any friction with the finish at all
__________________ -Goose 2002 Z06 Bone Stock 2001 ZR2 Bone Stock ------------------------------------------------- Free Our Troops! |
06-20-2008, 04:38 PM
|  | Senior Member | | Join Date: Jun 2007 Location: Raleigh, NC
| | | Re: Circles or Straight Lines? What is the source of TOWGT's conclusions? I encourage others who do this for a living to post their real world experiences.
__________________
Al
06-20-2008, 09:12 PM
|  | Senior Member | | Join Date: Mar 2006 Location: Mass.
| | | Re: Circles or Straight Lines? The theory is..sealants.. waxes do not dry completely flat...it has ridges but in micro sense....so in when light reflects the straight line application reflects better than a circular application...just like paint....do your wall in a circular motion and you will see them...straight line you will not...I know paint is thicker so more definition..but you get the idea....
AL |
06-21-2008, 01:22 AM
|  | Senior Member | | Join Date: Dec 2006 Location: Central Ca. (Hwy to Sequoia)
| | | Re: Circles or Straight Lines? Here is more curve ball to the issue. Swirls are straight line scratches that are reflecting/refracting light in what appear to be swirls. How else can they appear to be so concentric? Just something that I read.
I apply in overlapping circles for coverage. |
06-21-2008, 04:47 AM
Originally Posted by ZoranC May I ask which laws of physics (optics) would stand behind this? | Specula Reflection - Such behavior is described by the law of reflection, which states that the direction of incoming light (the incident ray), and the direction of outgoing light reflected (the reflected ray) make the same angle with respect to the surface normal, thus the angle of incidence equals the angle of reflection; this is commonly stated as θi = θr.
|  | | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | » Popular Product Links | | | » January 2009 | | S | M | T | W | T | F | S | | 28 | 29 | 30 | 31 |
