06-10-2008, 02:35 AM
|  | Senior Member | | Join Date: Mar 2006
| | | Re: Recommendations of Wheel Cleaner Quote:
Originally Posted by hondajake Thanks again. I wash my cars once a week and I use DP Gel once a week and still not getting the results I want... I will try the P21S cleaner and Megs to see what happens.... | if you have Big Lot's near by, you can get OTC Megs wheel cleaner for $3.50 instead of $7 @ Kragen.
If you get Wheel Brightener, be VERY CAREFUL, as this stuff is so acidic, it can cause skin burns. Wear gloves and rinse yout wheels well, as well as your hands, before even taking gloves off...
__________________
1997 Acura 3.2 TL (sold)
07-03-2008, 10:14 PM
|  | Senior Member | | Join Date: Aug 2007 Location: Mid-Michigan
| | | Re: Recommendations of Wheel Cleaner I ended up getting P21S Wheel Gel and Cleaner and used them both and then a coating of PB's Wheel Sealant, and the rims look great!
Thanks guys! |
07-04-2008, 01:30 AM
| | Senior Member | | Join Date: Dec 2006
Originally Posted by hondajake Hello All,
I was wondering if you could help me in deciding which wheel cleaner to get. I am using DP Gel Wheel Cleaner and it seems to do an OK job, but it does not remove harder containments. I have some brown dirt sports on my rims that I can not get off, not even with a sponge and some tar too. | Sorry to break in on this post but just curious about dirt spots on wheels, are they a normal occuarnce even if they are cleaned weekly or is it because they were left dirty for a while? I should be getting my first set of new wheels next week, just wasn't sure what to expect and what to buy as cleaners.....will a mild cleaner (i.e P21S) pretty much cover it, if cleaned every week?
Howard |
07-04-2008, 09:55 AM
| | | Re: Recommendations of Wheel Cleaner I bought the car used with 13K miles (2006 Acura RSX S) in June of 2007 and the rims had the dirt spots on them. I have been trying to get them off with DP Wheel Cleaner with no success. I asked around and I ened up going with P21S both cleaner and gel. Worked great at getting the spots out, infact they are no longer there. I tried P21S wheel cleaner in the past and thought it to be too expensive but it does the job.
07-04-2008, 10:22 AM
| | Junior Member | | Join Date: Mar 2008
| | | Re: Recommendations of Wheel Cleaner you may try to use the clay left from detailing the paint to clean the dirty spots on wheels~ |
07-06-2008, 07:22 PM
|  | Senior Member | | Join Date: Dec 2006 Location: Rolling Meadows, IL (NW Burbs of CHI)
| | | Re: Recommendations of Wheel Cleaner Another tip, after you get your rims as clean as possible, seal them with a sealant (I prefer DG 105). This will make future cleanings much easier; all you should need is your regular car wash soap and some brushes to clean them, as the sealant doesn't allow the brake dust to stick as well.
Pete |
07-06-2008, 07:30 PM
| | | Re: Recommendations of Wheel Cleaner I put PB's Wheel Sealant after I got them cleaned up on Thursday night.
Thanks for the tips! |
07-08-2008, 01:04 PM
| | Senior Member | | Join Date: Mar 2007
| | | Re: Recommendations of Wheel Cleaner I sometimes get a bit carried away cleaning rims and after trial and error - a lot of $$ error, here is my technique: rinse, wash with normal car wash, rinse, if bad - Megs Wheel bright 1:1, (spray, scrub, RINSE! - do not let sit) dry, polish with a Mother's mini powerball and the polish specific for the material, wash, dry, proctect with your choice - I like plain old AW. |
07-08-2008, 06:16 PM
| | Senior Member | | Join Date: Apr 2008 Location: Rock Hill, SC
| | | Re: Recommendations of Wheel Cleaner If wheels are not to bad I use car wash soap, if I need some more power I use Meg all wheel cleaner or Eagle One |
07-08-2008, 06:55 PM
|  | Moderator | | Join Date: Mar 2006 Location: South Florida
Originally Posted by hondajake I ended up getting P21S Wheel Gel and Cleaner and used them both and then a coating of PB's Wheel Sealant, and the rims look great!
Thanks guys! |
good and safe choices ...  |  | | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | » Popular Product Links | | | » November 2008 | | S | M | T | W | T | F | S | | 26 | 27 | 28 | 29 | 30 | 31 |
| 1 | 2 | 3 | 4 | 5 | 6 | |
