Featured Photos
by admin
531 photos
23 comments
by Unregistered
Interior Gallery
6 photos
3 comments
by Unregistered
Before & After
13 photos
3 comments
by admin
531 photos
23 comments
» Autogeek Car Care Products
Tags: , ,
Reply
Thread Tools Display Modes
  #1
Old 07-25-2006, 10:57 PM
Klasse AIO alternatives
OK, I think I'm almost set. Here's my current list for my next order:
  • Grit guard
  • Blue and white polishing pads (already have some but want extra)
  • DP or Optimum no rinse wash
  • Wolfgang leather conditioner
  • Poorboy's EX-P sealant
  • Poorboy's S&G
Originally, I was going to get Klasse AIO and SG. However, they require shade or a garage for application. That's a luxury that I don't always have. Therefore, I've decided on the Poorboys EX-P sealant.
What is a good Klasse AIO alternative...specifically, I'm looking for a non-abrasive polish alternative.
I already have Meguiar's DACP and Speed Glaze for abrasive polishes. Is Poorboy's Professional Polish a non-abrasive AIO alternative?
http://www.autogeek.net/pbpp16.html
Its description says it "minimizes scratches and swirls" so I was wondering if it's abrasive or not.
What about DP Final Finishing Polish or Wolfgang Prewax Polish Enhancer? Those seem like non-abrasive choices as well. How are they in full sun applications?
  #2
Old 07-26-2006, 12:27 AM
wytstang's Avatar
You can use AIO in the sun, I use it all the time with no ill effects. It's a WOWO product so you don't leave it there to dry. You do a panel then wipe down the panel.....
  #3
Old 07-26-2006, 12:30 AM
3Dog's Avatar
Klasse AIO should be left to dry (haze)...SG can be used in the WOWO method.
__________________
Ric
HOGtailing is my business
Detailing at the Dog
  #4
Old 07-26-2006, 12:53 AM
wytstang's Avatar
Nope
Quote:
Easy Application. Simply wipe on and wipe off, car care doesn’t get any easier. Use a Cobra Microfiber Detailing Cloth to make the job even easier. One folded towel is also perfect for applying a thin film of Klasse All-In-One. Use a second towel to wipe area and remove residue. There is no need to wait for the polish to dry or haze. We recommend using this polish in sections on your vehicle or boat, applying and wiping off as you make your way around all surface areas. Turning and refolding the applicator towel frequently will ensure maximum results.
  #5
Old 07-26-2006, 07:22 AM
killrwheels@autogeek's Avatar
Moderator
I think most have proven the Klasse AIO and SG are quite versatile. They can be used as WOWO (with SG it is easiest for removal) and allowing to dry/haze. I would not use SG in direct sunlight however.
Most of the products that are similar are likely to be "best" used in shade or garage also. With a cool finish, you can work them longer. Most use some light abrasives (like WG and DP Finishing polishes) and some use chemical cleaners (AIO). I believe Poorboys ProPolish is a combo of both.
  #6
Old 07-26-2006, 10:35 AM
scooterguitar's Avatar
AIO let me down last week! Doing a fresh prep on black. The AIO left haziness for some reason, I couldn't get it out! I tried QD and everything, no luck. Finally went over the AIO with a cleaner and it looked fine. I have never had that type of trouble with it!
__________________
Nevermind my typos!
  #7
Old 07-26-2006, 10:55 AM
AIO has been working great in Florida for me. My buddy loved how it cleaned up his 98 bird and then topped with DP Sealant. Seems to work well, in sun/shade.
  #8
Old 07-26-2006, 10:58 AM
How are you guys applying AIO? I just put some on a yellow foam pad and apply like a wax and buff off. I tried doing it by PC but didn't seem to work well. The pads seem to absorb the AIO and felt like I was just "dry buffing" I guess you could say. Plus my truck is white which makes it kinda hard to use, I found spots days later that I had missed even though I went over buffing a few times to make sure, it blends with a white paint lol.
__________________
The real WyStang:
  #9
Old 07-26-2006, 11:05 AM
Same old way I always have, with a pad wowo, never had troubles before.
__________________
Nevermind my typos!
  #10
Old 07-26-2006, 11:40 AM
FloridaNative's Avatar
Moderator
I believe that PB's Pro Polish is just a cleaner without abrasives, but let me go and grab my bottle just to be certain. Meg's #9 is a really good paint cleaner too. It makes the paint squeak literally, you just have to be super careful with the trim because it does stain. Hang on and let me grab my pro polish....Okay I'm back! Dang, now I don't know. From reading the back it's hard to tell. Here is what it says on the label....
Poorboy's Professional Polish is a specially formulated product for the professional as well as everyday people. This special formula has no wax and no silicone. "Body Shop Safe". Poorboy's Professional Polish can be used in the sun. It removes oxidation, road grime and returnes the surface back to it's original smooth, shiny and easy to maintain finish. It will also remove fine scratches, swirl marks, bird dropping and water stains (acid rain). Can be used on freshly painted surfaces as a final polish (usually from wet/dry sanded 2000 grit). It is safe on all paints, clearcoats, plastics and glass. Poorboy's Professional Polish can be used by hand, professional buffer or polisher. Poorboy's Professional Polish can be used on all types of metals as a de-oxidizer and restorere including: Aluminum, brass, copper, stainless steel, gold , silver, chrome (which is really a plating), and Lead (older paints).
It does say that it can remove some light swirls so maybe it has abrasives?? But it also says for deeper swirls, scratches and oxication to use SSR1
I've always thought it was just a solvent cleaner, but now I'm not sure. You know what, let me ask Steve and I'll post the reply.
__________________
Oye como va mi ritmo bueno pa gozar
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Porter cable w/ klasse AIO Mr.Clean3000 Porter Cable 7424 & Buffing Pad Forum 5 02-25-2008 08:00 AM
If I use SSR 2.5 + SSR 1, can I still use Klasse AIO? m4gician Auto Detailing University 6 06-09-2007 04:25 PM
klasse AIO questions paradog Auto Detailing University 3 05-03-2007 11:14 PM
What am I doing wrong with Klasse AIO??? brig2221 Auto Detailing Forum 10 04-01-2007 07:58 PM
Klasse AIO on headligts??? Gary Sword Auto Detailing Forum 18 01-01-2007 11:08 AM
» November 2008
262728293031 1
2 3 4 5 6 7 8
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 123456
