05-14-2008, 01:36 PM
|  | Moderator | | Join Date: Jan 2007 Location: Florida
| | | Re: DP Gel vs P21S Gel If you want something less aggressive and less expensive, why not just dilute the DP?  |
05-14-2008, 01:43 PM
| | Senior Member | | Join Date: Jun 2007 Location: Atlanta, GA
| | | Re: DP Gel vs P21S Gel Quote:
Originally Posted by matt@autogeek.net If you want something less aggressive and less expensive, why not just dilute the DP?  |
If diluted (any suggestions for ratio?), can it be left on wheels while all wheels are being agitated and then rinsed off? |
05-14-2008, 02:14 PM
|  | Senior Member | | Join Date: Oct 2007
Originally Posted by matt@autogeek.net DP is definitely stronger...that wheel cleaner is made with professional detailers in mind, who do not have time to sit around and wait for the cleaners to take effect. Each one has its own place in different people's detailing arsenals! |
i agree they both have their place, i have plenty of time to let P21S work, but even after letting it sit for an hour DP still did a better job. |
05-14-2008, 03:00 PM
Originally Posted by makdaddy626 If diluted (any suggestions for ratio?), can it be left on wheels while all wheels are being agitated and then rinsed off? | I'd probably start with something like 3:1 water  P and take it from there. At this ratio, I don't see any problems leaving it on the wheels for a couple minutes.  |
05-14-2008, 05:28 PM
| | | Re: DP Gel vs P21S Gel DP is pretty good stuff, but I hate the DP sprayers. They "stream" rather than "spray". I've found the Surf city cleaner to be very good and easy to work with, plus the sprayer is great. |
05-14-2008, 08:05 PM
|  | Moderator | | Join Date: Mar 2006 Location: South Florida
| | | Re: DP Gel vs P21S Gel I have used P21S without issue for years, and found DP no better. Both are nice options, but with high dollar forged wheels I will stick with P21S.
Did you use it correctly ?? Allow to sit for two minutes. Agitate as needed, and spray off ?? |
05-14-2008, 10:33 PM
Originally Posted by purplenurple DP is pretty good stuff, but I hate the DP sprayers. They "stream" rather than "spray". I've found the Surf city cleaner to be very good and easy to work with, plus the sprayer is great. | Yes, there is a fine line between closed and streaming, but if you adjust properly, they are great sprayers. |
05-15-2008, 09:43 AM
Originally Posted by killrwheels@autogeek I have used P21S without issue for years, and found DP no better. Both are nice options, but with high dollar forged wheels I will stick with P21S.
yep used correctly, i believe its a good product i just dont see it any better than DP.
i've left P21 on from 2 minutes to one hour..no better cleaning in time difference.
like i said its a good product i just dont see it as any better or safer than DP, if left DP on for up to 20 minutes with no ill effects so i think its pretty safe too |
05-15-2008, 01:16 PM
|  | Senior Member | | Join Date: Mar 2007 Location: Windsor, Ontario
| | | Re: DP Gel vs P21S Gel I just got in some of the DG 821, all wheel cleaner. At $24./gallon it's a bargain compared to most others. I have only tried it on one wheel so far and it did a fantastic job. I have 2 details to do this long weekend, so I'll try it out on them.
__________________
2004 Infiniti FX35
05-16-2008, 04:16 AM
|  | Senior Member | | Join Date: Mar 2006
| | | Re: DP Gel vs P21S Gel I love how P21S gel foams up!
__________________
1997 Acura 3.2 TL (sold)
|  | | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | » Popular Product Links | | | » January 2009 | | S | M | T | W | T | F | S | | 28 | 29 | 30 | 31 |
