Quote:
Originally Posted by Mr Dream Machines Werkstatt is far superior to Klasse and what all of you americans don't seem to understand is that to easily remove acrylic sealants, you should be using hot or warm damp microfibre towels and not leave the prime on for more than 10 to 30 mins |
I think what people don't seem to understand is that if you are having to use unusual techniques such as hot water to remove Werkstat, you used too much. These words are straight from Jeff Brandt, president of Jeff's Werkstat.
When I apply Acrylic Jett I continue to work it in and continue spreading it to elimate "high points" that will need to be buffed out. I continue spreading until I can not longer see it on the paint, only the shine it gives off while it is still wet. I use less than half an ounce (approx 15 ml) in one application. When doing so, buffing with a dry towel is almost effortless.
In an e-mail from Jeff Brandt, he has mentioned that professional detailers have mentioned to him they get around 50 uses per bottle. That equates to using about a third of an ounce. I would imagine most people are using way too much of the product resulting in their difficulties removing it.
