Quote:
Originally Posted by Meghan Hopefully Wet Sanding is not needed, a good polish should take care of it. |
Especially if they are still fresh. It's the etched water spots that are left on the paint baked in the sun and or acid rain spots which will require sanding. Fresh water spots can be wiped off with a QD (if still fresh and a good LSP) or a paint cleaner will take care of them. If that still doesn't work, a light polish. Since you waxed over the spots, you'll have to remove the wax to get to the spots.
