Quote:
Originally Posted by MadOzodi Ah ha...
Al, would DG601 negate PO115? |
I am not sure..but a wild guess would say yes...worth trying any ways....the 601 is a cleaner..not to strong but may be enough to clear the menz.......
you can just do the sealant right over the Menz glaze...I like the menz glaze..but its not a real wet look..more deep and warm looking...
I used 105 right over the glaze...my method was I glazed...wiped off..let it sit a hour after buffing..used AW on top of it to sorta seal it..then did 105 over the AW..worked out fine....lasted from middle May till late August....with just washings as i wanted to see if it failed...and it did good...
AL
