07-01-2006, 05:59 PM
|  | Member | | Join Date: May 2006 Location: Stillwater, MN
| | | First time over the car..... Just finished my first detail with my new XMT products and I have hazing. I did a search and it seems that maybe I didn't let the 7424 work it long enough. I used a clay bar first, followed by XMT3SR, followed by XMT Carnuba finsihing glaze and then finished with PS. To eliminate the hazing do I need to start completely over again or just go back to the XMT3 and work it longer? How do you tell if you've worked it long enough - does it completely disappear? I'm doing this on a black '04 CTS-V. Any pointers will be greatly appreciated.  |
07-01-2006, 07:01 PM
|  | Senior Member | | Join Date: Mar 2006 Location: San Diego
| | | It should look like it is barely there. You should expect to spend about 3-5 minutes per section. PC is slow, but designed to be almost perfectly safe if following the directions. Hazing can be removed by a lower step polish, or you might need to use a less aggressive pad with the #3. |
07-01-2006, 07:17 PM
| | Senior Member | | Join Date: Apr 2006
| | | more polishing it needs......... |
07-01-2006, 08:18 PM
| | The finish looks good, just hazed. Should I step down to a lower number XMT SR or would another product work better?  |
07-01-2006, 08:22 PM
| | Quote: |
Originally Posted by TNT-C5 The finish looks good, just hazed. Should I step down to a lower number XMT SR or would another product work better?  |
hazing or cloudyness???? |
07-01-2006, 08:23 PM
| | | It all depends. There is no real formula for removing haze. Try using a lower number product, and if that doesn't work, you might try different pads. It can be tough, but be careful to use the least aggressive combo possible. |
07-01-2006, 08:52 PM
| | Quote: |
Originally Posted by BILL hazing or cloudyness???? | Haziness...cloudyness?? I'm not certain what the diff is. Can you explain? |
07-01-2006, 08:54 PM
| | Quote: |
Originally Posted by TNT-C5 Haziness...cloudyness?? I'm not certain what the diff is. Can you explain? | SORRY! I meant streaking or cloudiness??? |
07-01-2006, 08:57 PM
| | Quote: |
Originally Posted by BILL SORRY! I meant streaking or cloudiness??? | Cloudiness. |
07-01-2006, 09:41 PM
|  | Senior Member | | Join Date: Mar 2006 Location: Overland Park KS
| | | TNT: you might try doing a panel with XMT until the product almost disappears, then wipe the remaining off using a quick detailer and an mf towel. I got the same cloudiness on a Black Roush at first and this did the job.
Totoland Mach
__________________ |  | | | Thread Tools | | | | Display Modes | Linear Mode |
| 1 | 2 | 3 | |
