Featured Photos
by admin
531 photos
22 comments
by 95se
Exterior Gallery
55 photos
33 comments
by admin
531 photos
22 comments
by admin
Sema Show 2008
433 photos
6 comments
» Autogeek Car Care Products
Tags: ,
Reply
Thread Tools Display Modes
  #1
Old 07-01-2006, 03:28 PM
scooterguitar's Avatar
Engine detailing
So I figure this is the next step to learn!
I have used a simple degreaser and hosed the engine off before with decent luck, although my car didn't want to start once!
First off, any methods you suggest?
Second, I heard this from a guy last night, who used to detail full time, said it was a great trick. After you degrease, have the car running, then spray tire shine on/in the engine, let it run for ahwile and as it works it way through belts and such with the heat form the engine going it basically adheres itself to it and make sit look great. Whatta ya think?
__________________
Nevermind my typos!
  #2
Old 07-01-2006, 03:31 PM
abrcrombe's Avatar
Aren't you supposed to cover some parts of the engine before washing it down? I've heard aluminum foil works great for covering the engine parts. I am afraid of cleaning the engine. One time I washed my bro's engine and it wouldn't start! Not just once, but at all! No one knew what I did and just assumed it was because the car is old.
  #3
Old 07-01-2006, 03:36 PM
That's funny dude!
I think stay away from some parts, but I forget the parts.
Someone will chime in here soon I imagine.
__________________
Nevermind my typos!
  #4
Old 07-01-2006, 03:37 PM
justin30513's Avatar
24 HR Queue
I do this very same thing. I use a pressure washer though with the first major detail. Uses less water and more air. I then use a silicone based spray to coat the engine bay. I close the hood and leave it running while I wash and rinse the rest of the vehicle.
I call it a baking process. The seems to give the dressing a curing process and all the runs are gone. Done it this way on 100+ rides with no probs and the customer loves it. Easy to rinse off for about a month.
  #5
Old 07-01-2006, 03:38 PM
killrwheels@autogeek's Avatar
Moderator
If you keep your underhood area up monthly there is no need to deep clean. I klasse aio all painted parts, and I use 303 Protectant on all lines and rubber.
When I recently sold the CTS, it needed a better bath. I used the DP Exterior Cleaner full strength, and allowed to sit on a cold motor. I then fired up the car, and then streamed the water, careful to stay away from the coils. It all ended well and the heat kept the water from getting into areas where it should not. I did NOT use high pressure, and allowed the cleaner to do the work. After running for 5-10 minutes with hood closed , I then opened and dried any spots and then went to work with the Klasse AIO and 303.
  #6
Old 07-01-2006, 03:45 PM
So with either method, no need to cover any parts?
__________________
Nevermind my typos!
  #7
Old 07-01-2006, 04:32 PM
24 HR Queue
I never do. I do try to stay away from directly soaking anything of importance. Under the hood is kinda designed to take the elements.
  #8
Old 07-01-2006, 05:31 PM
Later engines shouldn't have a problem with water, it's the older ones where you have to start covering stuff. On my truck I can soak the hell out of the engine and wash down and it'll start right up as normal. Ford's newer engine bays are well sealed and protected.
  #9
Old 07-01-2006, 05:32 PM
abrcrombe's Avatar
What parts would you consider "of importance"?? I'm not well versed with engine components.
  #10
Old 07-01-2006, 06:44 PM
dakevmann's Avatar
I usely avoid spraying the fuse box the computer and the coil packs directly with a hard stream of water. A light spray will generaly not hurt anything in newer model engines because of how well thay are sealed. Also most of the important parts like you CPU are coverd will a pretty think layer of silicone. I would suggest to spray it down with the engine running so you know if you spray something you shouldnt, but for the most part I wouldnt worry to much.
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Engine Detailing Information Fredrick2003 Auto Detailing Forum 12 10-03-2007 05:25 PM
Engine detailing mistakes and how to fix? MTHall51 Auto Detailing Forum 16 09-18-2007 11:27 AM
Engine detailing product - recommendations? MTHall51 Auto Detailing Forum 22 08-18-2007 07:46 PM
Engine Detailing Lone_Star Auto Detailing University 30 03-21-2007 09:22 PM
Engine Detailing cummins03 Auto Detailing Forum 13 05-15-2006 07:18 PM
» November 2008
262728293031 1
2 3 4 5 6 7 8
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 123456
