11-09-2007, 01:58 AM
| | Senior Member | | Join Date: Apr 2007
| | | Couple Questions Regarding XMT 360 Sorry if this has been said before... I did search
Anyways, I just ordered some xmt 360 and natty's red (i have been using the blue, and like it; see sig). I hear that 360 is a sealant as well as a 1 step polish, but have heard that it can be used with an orange pad?
I purchased the 360 with a 1 step polish in mind for those cars that were already in good condition, but am wondering if i could use it to replace XMT1/2 (w/ white pad).
Also, it is a sealant, but says it needs no curing time. Will it be ok to put some Natty's over the 360 once i am done polishing with it?
thanks for the input, i know i will have more questions soon enough
__________________
CLICK IT.... I know you want to |
11-09-2007, 02:12 AM
|  | Senior Member | | Join Date: Mar 2006
| | Quote:
thanks for the input, i know i will have more questions soon enough  | XMT 360 correctimg ability is really pad dependant. Use it with orange pad, to remove light swirls. It is a one stepper polish/sealant, with no curing time. You can top it off with Natty's Red right away.
__________________
1997 Acura 3.2 TL (sold)
11-09-2007, 02:26 AM
| | | thank you! this is the answer i was looking for.
can i use this on a car with light-med swirling? or is the paint correction really that little?
thanks again!
__________________
11-09-2007, 05:41 AM
|  | Senior Member | | Join Date: Nov 2006
| | | its only ment for very light scraches and it does fill some of those
__________________
names tom i live in nj with my wife and my daughter samantha born 8/23/06 shes so awesome .we love her so much! |
11-09-2007, 06:05 AM
| | Quote:
thanks again! | You are welcome. Light yes, moderate - some will be removed, some will still remain; might take you 2-3 passes.
__________________
11-09-2007, 08:51 AM
|  | Senior Member | | Join Date: Sep 2007
| | | how does the cut of xmt360 compare to xmt1 or xmt2?
Thanks |
11-09-2007, 09:00 AM
| | Senior Member | | Join Date: Jun 2007 Location: Atlanta, GA
| | Quote:
Originally Posted by MoBenzOwner how does the cut of xmt360 compare to xmt1 or xmt2?
Thanks | I've used it but would be hard pressed to assign a value to it's cut because it does contain fillers. I don't think it will REMOVE as many imperfections as XMT 2, but between removing and filling will look like it did more than XMT 1, at least for a little while (until the fillers are gone). |
11-09-2007, 09:16 AM
|  | Senior Member | | Join Date: May 2007 Location: belton,tx
| | | 360 is a maintain polish and should only really be used on a brand new car, or one that has been properly polished to remove swirls. Correction is minimal, fillers are great and durability is ok. Definately top with Natty Red and you will get fantastic results!!!
__________________ "When life hands you lemons, make faces at it!" (my boy) |
11-09-2007, 09:31 AM
|  | Senior Member | | Join Date: Jul 2006 Location: Ft Lauderdale, Florida
| | | This is off of the AG website, doesnt say anything about fillers...I was under the impression it didnt have any fillers from this.... Corrects. XMT 360™ does what no mere cleaner wax can do; it removes light swirls and imperfections to leave the paint looking flawless. Ultra fine abrasives - so fine they are not perceptible by sight or touch - gently blend away fine blemishes and visibly smooth the paint. Light spider webbing and water spots vanish. XMT 360™ works like a mild swirl remover but, remarkably, it eliminates the need for a separate cleansing lotion or sealant.
And then it also says: XMT 360™ by Pinnacle is a revolutionary new product that combines correction, cleaning, and sealing into one simple step. This all-in-one wonder eliminates the need to use a separate mild swirl remover, paint cleanser, and sealant, yet you achieve the same depth, gloss, and slickness! XMT 360™ is total car care made easier
__________________
Darren
11-09-2007, 09:56 AM
| | | 360 does contain fillers. I know from experience and it's been well documented on the forum. While you're correct that it doesn't explicitly say that in it's description, that's not uncommon. Many products that contain fillers don't advertise it. But, with 360 look for what is NOT said in it's description... if you look at the pure polishes from XMT you find a statement like this: XMT Intermediate Swirl Remover contains no fillers so you can see the results of your work
You won't see a statement like that in the 360 description. |  | | | Thread Tools | | | | Display Modes | Linear Mode |
| 1 | 2 | 3 | |
