Featured Photos
by admin
531 photos
23 comments
by admin
531 photos
23 comments
by admin
Before & After
13 photos
3 comments
by admin
Sema Show 2008
433 photos
10 comments
» Autogeek Car Care Products
Ice Master Multi Blade ice scraper
Reply
Thread Tools Display Modes
  #1
Old 11-01-2007, 04:46 AM
TOGWT's Avatar
Polymer sealant (Chem 101)
I have been asked on a few e-mails to provide a simple chem explanation of polymers that are used in sealants-
Polymer: [: a chemical compound with many repeating structural unit, or monomers]
From the Greek: πολυ, polu, many; and μέρος, meros; part.The molecular structure of all polymers are based on a chain of carbon atoms, chemically it is a molecule formed by the chemical union of five or more identical combining units called monomers. A non-organic based wax formulated from polymers used to seal paint with a thin hard barrier. They are very durable and provide a very bright, but flat silvery shine. This type of product is a compromise as it does provide durability but lacks the properties of a Carnauba wax lacking both colour and depth, and because of a polymer's inherent Covalent (molecular) structure it cannot mimic the properties of a Carnauba wax.
If not properly engineered, polymer sealants may crack, yellow or distort the optics of the paint surface.Most quality polymer based sealants contain amine silicones (reactive alkoxy group) as well as a blend of resins and a small percentage of wax. Polymers used in sealants require a paint surface form a molecular bond to; they don't do well when asked to bond to metal to provide protection. A clear coat (paint) has porosity, so they bond very well and provide the intended protection. Since clear coat paint has porosity, a durable bond is formed and provides the intended protection.
The presence of oil or water may inhibit the cross-linking process of a polymer or linking together of the chains (monomers or building blocks) to form a ‘structure’ by acting as a barrier and will compromise its strength, durability, drying time, and bonding. Be sure that the surface of the vehicle can be left undisturbed and free from rain and water (condensation, dew,etc)) until the polymer has cross-linked (12-24 hours) or the surface protection may be compromised.
To provide a ‘clean’ oil-free paint surface to enable proper cross-linking use a polish that does not leave behind oils, or use an Isopropyl alcohol / distilled water ‘wipe-down’ or a chemical type paint cleaner (AIO)
Avoid were possible any moisture as the active ingredients (i.e. what isleft behind in the form of a film after application) will be diluted or washed out, negatively affecting its durability. That's why you should avoid rain, even morning dew with any curing sealant layers for at least 12-72 hours (product dependent). So, when you spray water on to a curing sealant, you are compromising its durability.
Fracture/evaporation temperatures - Polymers 350 oF (176°C), Acrylic resin 265 - 285 oF (130 - 140°C)
The term "melting point" when applied to polymers suggests not a solid-liquid phase transition but a transition from a crystalline or semi-crystalline phase to a solid amorphous phase. Melting temperature though abbreviated as simply Tm the property in question is more properly called the "crystalline melting temperature". Among synthetic polymers, crystalline melting is only discussed with regards to thermoplastics, as thermosetting polymers will decompose at high temperatures rather than melt.
Polymer application- ease of product removal is inversely proportional (less product easier removal) to the amount used (0.5-1.0 oz should be sufficient for most vehicles)
TOGWT ™ Copyright © 2002-2007. Jon Miller, all rights reserved
  #2
Old 11-01-2007, 05:49 AM
supercharged's Avatar
I see some usefull information here. Thanks for sharing.
__________________
1997 Acura 3.2 TL (sold)
  #3
Old 11-01-2007, 01:31 PM
Jon, how you feel about further Polycharging existing sealants that already have Polycharger in them (Ultima)?
  #4
Old 11-01-2007, 01:50 PM
wytstang's Avatar
That's a bit more difficult for those of use that don't have garages. Great info I really enjoy reading your post as they are always very informative. Thanks for taking the time.
__________________
Surfer Caught on tape
Surfer after months of icing down your........how do you feel?
  #5
Old 11-01-2007, 04:02 PM
trlblazer3's Avatar
Wow lot's of good stuff in there. Thanks for the info!
  #6
Old 11-01-2007, 06:53 PM
killrwheels@autogeek's Avatar
Moderator
where's the quiz ??
  #7
Old 11-02-2007, 02:57 AM
klumzypinoy's Avatar
Thanks a lot TOGWT!
__________________
Quote:
Originally Posted by trhland View Post
hes the one that asked what kind of sham poop does paul dalton use
Quote:
Originally Posted by makdaddy626 View Post
Klumzy, do you think there would be any of issues if you used "shampoop" + wax? j/k couldn't resist.
Might be a perfect time to try out Klumzy's "Shampoop" on carpet.
  #8
Old 11-02-2007, 06:00 AM
dengood1's Avatar
AAAAHHHHHHH..........my head hurts now Good info TOWGT.......thanks!
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Sealant Help billmacomber1987 Auto Detailing Forum 8 12-20-2007 07:14 PM
Meguairs Polymer Sealant jam Auto Detailing Forum 14 08-15-2007 03:37 PM
NEW FORMULA! DP Premium Surface Shield Paint Sealant Meghan New Car Care Products 37 08-18-2006 07:41 PM
DP Paint Sealant On Sale Jason DP 15 08-03-2006 02:41 PM
Sealant & Wax Combo vtise Auto Detailing Forum 12 06-19-2006 10:11 AM
» December 2008
30 1 2 3 4 5 6
28 29 30 31 123
