Hand sanded with foam sandpaper 3000 grit. I did three passes on the door panels and 4-5 on the hood and top. I used a bigfoot 6 inch with microfiber pad and did about 3-4 passes with the heavy compound. Polished it then ended with a wax. Looked like New when I was done. I did have another case on a black Mercedes that had it bad on the hood and trunk. I used the same process on two occasions because it resurface but it was to far into the clear coat so there was no fixing it.
