Re: What is the best way to tackle these wheels?
Coating them will be a big help. Once coated a pressure washer will get them mostly clean and a quick agitation is all that should be needed.
For cleaning on those I'd use a lamb wool mitt for the faces, EZ brush for the barrels, and standard 1"-1/5" detail brush for the lugs.
Just use some flag tipped brushes for the face and spokes and lugs, then a ezdetail brush for the barrels.
Those spokes are big enough you can use a wheel brush
Wheel Woolies 3-Piece Kit, wheel cleaning tools, wheel brushes
CarPro Hydro2 Touchless Silica Sealant, spray on car wax
You can thank me later.
Wheel woolies make cleaning wheels a breeze.
Hydro2 will help protect the wheels and make them easier to clean.
And since Hydro2 is spray on, spray off, you dont need to worry about getting in all the nooks and crannies of those wheels and banging up your fingers!
Nice car
I use the speedmaster for in between and the mothers wheel brush for the faces and then a stiff low profile brush for the tires I like the tuff shine brush. Quick and easy and they come out looking new every time.
2016 TOYOTA TACOMA TRD OFF ROAD PACKAGE
I agree with either some wheel woolies and/or the speed master brush.
I also agree in coating the wheels to make life easier on yourself.
I have had painted black wheels in the past. Not as many spokes as what you have. But I ended up using this boars hair brush on the face of the wheels. It is a very soft brush.
Boar's Hair Wheel Brush
I also have one of these
Lug Nut Brush,Clean Wheel Brush,clean brake calipers, clean lug nuts, boar's hair wheel brush, best wheel brush, wheel lug nuts
This limited the marring I would get on the face of the spokes with other brushes.
For tire cleaning I use this. Probably the best tire brush I have used.
TUF SHINE Tire Brush
How often do you clean them?
I have these wheels and the wheel woolies are perfect. If you clean them regularly you won't need anything beyond soap and water.
I wouldn't do those with the with the Daytona/EZ brushes. Betting they're like the Vette black wheels, single stage, and stupid soft paint.
This wheel was brand new... only 751 miles, and washed with a Daytona/EZ brush.
The Wheel Woolies are much softer, and safer.
Wheel Woolies Car Detailing Brushes
The 3-piece is often spoken about, thing is... the little one is about useless.
Jus' sayin'.
Then there are the Wheel Woolie Boars Hair Brushes.
1" brush that is GREAT for tight spaces, around lug nuts, even grills, headlights, badging, jambs, tight trim areas etc.
Wheel Woolies Boar’s Hair Detail Brush 1 inch
Typical wheel brush... just happens to be boars hair.
Wheel Woolies Boar’s Hair Wheel Brush
@Cardaddy. What are the Wheel Whoolies made of?
By stanza387 in forum Auto Detailing 101
Last Post: 04-27-2016, 02:57 AM
By Dan Tran in forum Auto Detailing 101
Last Post: 10-28-2015, 09:04 PM
By Dixarect in forum Ask your detailing questions!
Last Post: 09-16-2015, 12:36 PM
By medicscott in forum Auto Detailing 101
Last Post: 06-25-2015, 04:44 PM
By jackychai in forum Auto Detailing 101
Last Post: 07-27-2012, 07:04 AM
