Advice for first coating?
With an early spring approaching I'm thinking about my spring cleanup for my vehicles. I have a '15 Subaru Outback and a '13 Mini Cooper S. I'm thinking that I'd like to coat both of them this year and I'm trying to decide between Optimum Gloss Coat, CQuartz, CQuartz UK or one of AG's house brands. I've been leaning towards CQuartz or UK after prepping with CarPro Essence. Any advice? Thanks in advance!
Re: Advice for first coating?
If your looking for ease and simplicity go with gloss coat,U.K. Maybe hard to rub off and cq finest you can onl get if your a authorized installer.
Will Gloss Coat look as good as UK and will it have similar durability and hydrophobic properties?
I applied CQuartz UK and have been happy so far with the results, so definitely worth looking into. Having said that there have been a lot of positive feedback on this forum of the Wolfgang Uber coating and since I have used the WG Sealer & Fuzion wax with excellent results, I may go to WGU coating although it is quite a bit more expensive than CQuartz
Sincerely, Bruce
2015 Ram Big Horn CC 3500 Cummins DRW w/AISIN tranny
I would advice you to go with Black Label Diamond Coating V2, it's one of the easiest coating to use and even if high spot occur you can remove them out pretty easy. Also they have fixed the beading problem already, now they will have more durability as well as super tight beading. Good thing is that it was design to accept wax or sealant top up as well, so you can amp up the shine anytime you want.
yes very nice gloss and durability.
I've used the DuraGloss Nano Glass ceramic coating as well as the Pinnacle Black Label 850 and without a doubt the PBL is the better of the 2. I applied it to my car this past fall and let me tell you, the clean up is a snap! Once done doing a RW or WW the car gloss is stunning. Its also as easy to use as the DGNCC was but is holding up better IMO and the previously mentioned looks
2022 Elantra N Cyber Gray
PBL is somewhat compelling but it's very expensive. Plus they don't have a paint coating only kit....only a kit with all of their coating products. Probably still between Gloss Coat and CQUK.
For ease of application, you cannot beat Gloss Coat. I personally prefer UK, but it has a learning curve which steers a lot of people away. It's very thick, very durable, nearly perfect to be honest. It will outperform what some coating companies call their pro ceramic coating too. But, like I said, if you are new to coatings, Gloss Coat cannot be beat in terms of ease of application. Many order both, and start with Gloss Coat learning the basics then move to UK. But if you are in a mild climate, try out CQuarts Standard, it's pretty easy too and really durable and glossy.
I live in the Northeast so it's definitely not mild, however I'll be waiting until late March or early April to apply. I'm assuming the temperature greatly affects application? Is there a big difference in look between Gloss Coat and CQUK? I've read that UK really deepens color and adds a lot of gloss.
By lukel90 in forum Auto Detailing 101
Last Post: 06-02-2018, 03:30 PM
By inDetail in forum Auto Detailing 101
Last Post: 08-19-2017, 02:11 PM
By 07rs in forum Auto Detailing 101
Last Post: 02-28-2015, 05:38 PM
By Corey@OptimalDetailing in forum Auto Detailing 101
Last Post: 11-25-2013, 01:08 AM
By jforget1 in forum Off-Topic
Last Post: 01-29-2007, 07:15 AM
