Coin-Op Rinse only In Winter?
Well the winter temperatures are finally here and they have started to salt the roads even though we have only had a dusting of snow. I don't have a garage and there are no touch-less washes within 30 miles of me. Would I be safe just using the coin-op to rinse my car wih water only to get the salt and stuff off and use the hand dryer to get most of the water off the car? Am I asking for water spots with this method?
- Better leaving it alone until we get safely above freezing to do my normal ONR?
- Take a gamble and use the coin-op high pressure soap(hope its not total crap) before rinsing?
Thanks for entertaining the craziness. Lol
Re: Coin-Op Rinse only In Winter?
I would consider using one of those spray booths to pre-rinse and clean wheels, wells, and underbody as possible. Get the salt off as soon as possible.
Having never lived in a freezing winter, I am certain others could share their best practices.
I go to the spray bays and knock off the salt crust with just water. I do have a garage and that is where i do my rinseless after. If no garage i would just spray it down as often as needed until the warm weather comes back.
No, you will not be able to dry after spraying the car because there will still be a film of dirt/road film/ etc. After spraying, give it a waterless/rinseless wash.
"I've seen a good quality car wash look better than some guys complete detail jobs."
Mike Phillips 10/21/09
You really need to use the coin-op soap. It may remove some wax, but it won't hurt the paint. If the temperature is above freezing use several high quality towels to dry as many panels as your can. If you have the time, apply something like Meguiar's Wash and Wax Anywhere to the wet vehicle one panel at a time before drying with the towel. Give the dried panel a quick buff with a microfiber polishing cloth. Presto...a winter wash and wax job.
Two white Tacomas and two black Harleys...No sense complicating my life with color.
I like what he said. He seams like he knows his stuff. I mean, who would towel dry just after only spraying down the car? Doesn't the coin-op brush serve a purpose? Yes, it does. To remove the dirt. If the sprayer removed all of the dirt, what's the need for the brush?
Not best practice.. But I literally don't wash the car during winter months
With the constant salt throwdown and kickup its a lost cause
During winter time, all I do is pressure wash the car with water only. Soap would not cause a problem but it's pretty much impossible to keep the car clean for more than a day here in Montreal... so I don't waste my time trying to get it perfect. For me, it's a matter or removing salt and grime, not making it look perfect.
The key is to apply a good protective layer before it starts to snow, and then just maintenance clean it during the winter months.
If you haven't done it already, Aquapel is amazing during winter. It makes removing snow and ice from windows so easy.
I use a slightly modified approach.
Once the weather hits and the temperatures get really cold, I only go through touch touchless car washes. I've found two or three in my area which have an undercarriage spray to get the salt off the important bits underneath.
Do the touchless washes get everything off? Nope. On my black car it's a little obvious, but when there is a constant pray of grime off the roads there is no real point in going for a show-quality wash.
I will admit things are a little different this winter. Yesterday I did treat my car to a touchless and then a waterless wash once I got home. The weather was just too warm not to take advantage of the situation.
By 2wookies in forum Auto Detailing 101
Last Post: 11-12-2018, 04:17 PM
Last Post: 03-14-2018, 09:26 PM
By emichon in forum Ask your detailing questions!
Last Post: 02-17-2014, 05:20 AM
By twobucket in forum Auto Detailing 101
Last Post: 01-01-2014, 11:18 PM
By aalbs in forum Auto Detailing 101
Last Post: 12-03-2012, 09:21 AM
