Page 1 of 3 123 LastLast
Results 1 to 10 of 24
    Oct 2014
    HELP! Used scotch gard oxy to remove pizza stain now looks worse
    I got pepperoni and cheese on my car seat. I got the chunks off then sprayed some Scotch gard oxy directly on the seat let stand 5 minutes then dabbed with a towel, now it looks like this. You can see the stain is still there and now there is the larger area where I sprayed that you can see. How can I get this out? I have never properly cleaned car seats before. If you look closely you can see there is a larger stain that goes across the whole seat, I dont know what that is, it was there when I got the car. Please help a nooby!
    Jul 2014
    152
    Re: HELP! Used scotch gard oxy to remove pizza stain now looks worse
    What do you have for tools?
    I recently had a cloth F350 with stains that my 'professional' chem wouldn't touch. I ended up using diluted simple green on the spot and the entire area, gently rubbing the area, then misted with warm water and extracted it using a vacuum. Came out like new after a few attempts.
    Not sure why my professional equip wouldn't do that job, but I run into it occasionally where household stuff works better
    Apr 2015
    175
    Oil based from pizza? Try a citrus degreaser or tanin stain remover. Meguiars sells them by the gallon for protein specific stains lol
    Oct 2014
    Quote Originally Posted by heckhole View Post
    My only tools are a craftsman wet-dry vac.
    Was it just the simple green all purpose concentrate? What did you dilute it to?
    Jul 2007
    Stratford ct
    967
    i have had good luck with spray dri foam carpet cleaner
    Apr 2012
    7,494
    rent a rug doctor and extract your seats while yu try to remove that stain too
    2019 Nissan Rogue SL
    Oct 2014
    I've seen some people recommending dilute dawn dish soap too which I may try first since I would have to buy the other products mentioned.
    What is the general idea of getting this stain out. Do I want to soak the area with the cleaner then agitate with a brush and then vacuum it out? I've never done this before and want to avoid permanent damage.
    Oct 2014
    Quote Originally Posted by custmsprty View Post
    This sounds like a great idea. It seems like I can rent for a day for $30. Do they typically come with cleaner or do I need to buy some? If I need to get some any recs?
    Super Member VP Mark's Avatar
    Jul 2012
    2,451
    Umm, try this before doing all that.
    Woolite 1:10 in a spray bottle of distilled water, agitate with soft brush, pat with Micro fiber, wet vac. Wash, rinse, repeat if needed.
    Visual Pro Detailing - Auto Detailing near Marion, IL. Call
    (618) 983-9706 www.visualprodetailing.com
  10. #10
    Oct 2014
    Quote Originally Posted by VP Mark View Post
    To rinse do I just do the same thing but with water in a spray bottle instead?
  1. How to remove this stain from the paint
    Last Post: 05-31-2019, 01:10 PM
  2. How would You get Remove this Stain from Dash?
    By Ericsworld in forum Ask your detailing questions!
    Last Post: 02-10-2019, 07:13 AM
  3. Remove this stain
    By nickyd845 in forum Ask your detailing questions!
    Last Post: 08-24-2017, 08:59 PM
  4. How to remove headliner water stain??
    Last Post: 12-04-2015, 03:52 PM
  5. How to remove a salt stain
    By Quikor in forum Auto Detailing 101
    Last Post: 03-08-2010, 04:25 PM
