car wax, car care and auto detailing forumAutogeekonline autogeekonline car wax, car care and auto detailing forum HomeForumBlogAutogeek.net StoreCars WallpaperLink To UsvBGarageGalleryDetailing How ToFollow us onTwitterFacebook
» Official Detail Fest 2010 Information Thread!!
» Current Poll
How do you prefer your information?
Paper Handbook - 23.53%
28 Votes
DVD - 12.61%
15 Votes
Digital PDF Download - 63.87%
76 Votes
Total Votes: 119
You may not vote on this poll.
Reply
Thread Tools Display Modes
Old 08-25-2007, 07:08 PM   #1
Questions about polishing...
Hey everyone...I have some questions about polishing. First off, I've read most of the topics on polishing & I appreciate everyone's knowledge. I'm new to polishing & I recently purchased the UDM along w/ Menzerna SIP and 106ff polishes. I was excited to get started, but I'm discouraged now because 2 people I've recently talked to think I'm crazy for polishing my car. I have a BMW Z4 and the one person told me that I would take the clearcoat and paint right off the car if I'm not careful, especially around all the curves on that car. The other person told me that there is no need to polish my car and I might cause more damage than good. My basic question is that if you polish a car just once a year, doesn't it take off just a little of the clearcoat? Does this mean over a short period of time, you will reach the paint layer?? I'm confused. I was really looking forward to this, but I'm kinda lost now. Any advice would be appreciated. Thanks so much...I've learned so much from this forum. By the way, I bought CCS 6.5" pads w/my machine...the blue, gray and white. Thanks again.
beemergirl is offline
Old 08-25-2007, 08:01 PM   #2
A1monky's Avatar
Dont worry about burning through your clear coat with a UDM. If you where using a rotary then yes, but a DA machine is very safe. Just be careful around corners. Make sure to not let more then one inch hang off the edge of any corner. I would reccomend getting some 4in pads. They can help get into those small spaces safely. And always use the less agressive method first. Dont start with the SIP, try the 106ff first and see if that works. Many people think that placing a machine on their paint is going to burn through their clear coat. Its mosly ignorance, or maybe a bad experience with a rotary. Many people on this forum use DAs, and we have our clear coat!! If you want a show car finish, you have to polish. Alot of focus is placed on wax, but polishing is what makes your car look its best.
I have not been polishing for a long time, but I am sure that many of members on this forum have. Maybe they could tell you how often you should polish in order to keep your clear coat intact.
Get out there and use your UDM!!!
A1monky is offline
Old 08-25-2007, 08:08 PM   #3
LazerRed1's Avatar
If you get rids of any swirls etc. then wash properly, you won't need an aggressive polish very often. The clear is thicker than you think. You'll probably trade cars before you work through the clear, especially with the UDM.
LazerRed1 is offline
Old 08-25-2007, 08:47 PM   #4
Thanks for your advice! I'm gonna get out there and make that puppy shine
Old 08-25-2007, 08:48 PM   #5
A1monky's Avatar
Quote:
Hell yea thats the spirit! I will be doing the same tommorow.
A1monky is offline
Old 08-25-2007, 08:52 PM   #6
Don't let the uninformed get to ya! Take your time, and check out some of the AG videos - UDM is just like a PC, just a little stronger
Junebug is offline
Old 08-25-2007, 09:34 PM   #7
Tonya's Avatar
You go girl! Don't listen to those other people. I bet they don't even wash their cars. I bet they take it to a car wash. They are not informed like you!
Alright we have another female in the group!
Welcome bimmergirl!
__________________
Thanks,
Tonya AKA twinkle toes
Even a mistake may turn out to be the one thing necessary to a worthwile achievement - Henry Ford
Tonya is offline
Old 08-26-2007, 05:40 AM   #8
Member
I just got into using a DA the UDM in fact and it is very easy. I dont think that you have to be all that carful even on the edges. But be carful all the same. I used XMT 4 wich is a compound on the trunk of my BMW 325IC and it worked like a charm I am not saying that nothing can happen but it is not likley plus you have a BMW and it has a very hard clear coat. You will love the machine.
Tragu is offline
Old 08-26-2007, 05:56 AM   #9
Totoland Mach's Avatar
Beemergirl: Maybe I can offer my $0.000002 (after taxes). I typically break down paint correction as follows:
1. Cutting (usually wet or color sanding to remove scratches or severe surface defects) and Compounding. Most cars can handles 2-3 cutting process during the life cycle of the car. A paint thickness guage is an absolute must to measure a starting thickness and an ending thickness. Most BMW's that I use the cutting technique have never had this process done. If they had a previous cutting process, I would know it when I used the paint guage. I use this process on areas where there is severe scratching.
Compounding is 90% of the work I do. Compounding with a compounding pad (sometimes called a cutting pad) or wool is for surface leveling and removal of all scratches and scrapes. Compounding also has different levels of aggressiveness. From a light compound like Optima to a heavy one like 3M Extra Cut.
2. Polishing. Polishing automotive paint removes light surface scratches and swirls. Following compounding (which actually produces uniform swirls of its' own), polishing brings the paint to the reflective surface you are looking for. Polishing a vehicle 2-3 times per year, depending upon vehicle usage, will not remove a measurable amount of clear coat.
3. Waxing. After the work is performed at the shop, the last step is protecting the work I've done. Because the cars I recondition are for resale, I don't know what the customer wants or how the customer is going to treat the car, so I give them the best possible paint preparation I can. I've had some customers bring their cars back to me after 1 year and they still look fantastic. I've had others treat their cars like Michael Vick's pitbulls!
So, polish away and enjoy your Z4!
Here are some visuals for reference:
First a BMW 745 with 1 door wet sanded (that door had been repainted by a shop and had a lot of orange peel finish) and the other door compounded.
Next up is a black Z4 that had a lot of scratches and swirls. This only required compounding as the base process
The compounding process actually produced more swirls which would be removed with polishing. This pic shows the compound swirls. I've seen cars in this condition that were "detailed" at a car lot....and left in that condition!
Finally, the finished Z4
And....the 745 doors that were wet sanded and compounded
Have fun!
Toto
__________________
Totoland Mach is offline
Old 08-26-2007, 07:07 AM   #10
Toto, I wish I could follow you around and just watch for a couple of weeks. You are a master, sir. Excellent work, as usual.
hydro556 is offline
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Menzerna Polishing Cream Metal Polish Meghan New Car Care Products 3 12-06-2007 05:10 PM
Lake Country Wool-Ball 3 inch & 5 inch Wool Polishing Balls Meghan New Car Care Products 3 11-09-2007 09:20 PM
First time questions about a PC and Polishing Charts darksparkz Questions about the Porter Cable 7424XP, 7424, 7336, Griot's and Meguiar's Dual Action Polishers 5 01-14-2007 02:15 PM
placing my first order but have questions about products shevie Auto Detailing 101 5 10-03-2006 05:23 PM
More polishing questions kellyinkc Auto Detailing 101 2 08-12-2006 02:47 PM
» March 2010
28 1 2 3 4 5 6
28 29 30 31 123
» Car Care Brands
Wolfgang MetallWerkâ„¢ Aluminum Polishing System
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43
