» Official Detail Fest 2010 Information Thread!! | |  | |
08-20-2007, 12:37 PM
#1 | | Member
| Duragloss #101 and #105
Whats the difference between DG 101 and DG 105? Is it smart to use 101 first and then 105?
08-20-2007, 12:45 PM
#2 | | Senior Member
I haven't used either but it looks to me like the 101 is an AIO cleaner/sealant and the 105 is only a sealant. I would guess they would work in the same manner as the Klasse twins, cleaner first, sealant second.
08-20-2007, 12:58 PM
#3 | | Senior Member
I have used a lot of DG products over the past year. DG101 is an all in one. It works well by its self. You can use DG105 over DG101 with great results. Let the 101 set for a few hours before you put the 105 over it.
08-20-2007, 01:05 PM
#4 | | Member
Okey. Shall I let 101 dry, and then wipe it of with a mf, or should I just put 101 on first, and then 105 and wipe them of together?
08-20-2007, 02:03 PM
#5 | | Senior Member
Join Date: Dec 2006 Location: Central Ca. (Hwy to Sequoia)
| Quote: |
Originally Posted by makdaddy626 I haven't used either but it looks to me like the 101 is an AIO cleaner/sealant and the 105 is only a sealant. I would guess they would work in the same manner as the Klasse twins, cleaner first, sealant second. |  . Al and Sparkie have a method of using #101; #105; and AW on white paint that is WOW.
08-20-2007, 02:06 PM
#6 | | Senior Member
| Quote: |
Originally Posted by Jimmie  . Al and Sparkie have a method of using #101; #105; and AW on white paint that is WOW. | Thats true! And its really WOW!!
__________________
Audi Allroad Quattro
VW Jetta 4 TDI
08-20-2007, 02:12 PM
#7 | | Senior Member
101 + Liquid souveran look awesome!!!
Thats what I am using now. seems to have great durability too.
08-20-2007, 03:57 PM
#8 | | Senior Member
| Quote: |
Originally Posted by Microlab Okey. Shall I let 101 dry, and then wipe it of with a mf, or should I just put 101 on first, and then 105 and wipe them of together? | Here's a post by Al-53 on DG101 and DG105 Quote: |
Originally Posted by Al-53 Bags..let 101 haze up for 30 minutes..depending on weather..if hot and humid go 45 minutes...if cool and dry go 30 ....buff it off.....wait 30 to 60 minutes before doing 105...let 101 start to link up a bit..that way you will not be pushing it around with 105...if you have time and not in a hurry...do 105 the next day...it goes on fast and easy....but do by hand...little trick...do a very lite spray of AW if you have it on the foam applicator pad and then a dime size of 105...that primes the pad some and helps 105 spread far..just need to do AW on the pad once..the 105 will continue the priming..I mean a lite spray..not soaking it...lol....just to make it slightly damp....
Use very little 105 as it goes a long ways after the pad is primed...
let 105 sit 1 hour before buffing off...better results...longer if you want
Al |
__________________
Alban B-)
2008 Ford F250 XLT 6.4L PSD, 4X4, SC, SB, Bedrug bedliner, Torza Trifold Tonneau cover, SS step bars / Dark Shadow Gray Metallic
2006 Nissan Sentra 1.8S / Inferno |
08-20-2007, 04:07 PM
#9 | | Senior Member
You can also try 501 then 105. #501 is a bit stronger then #101.
__________________
VW Jetta 4 TDI
#10 | | Senior Member
When doing the 101 and 105 combo....what I do sometimes is I do 101 in the morning....then late afternoon I do the 105....but if real humid I wait to next day
The Ideal way is to do 101 one day and 105 the next....101 has a more sealant property than Klasse AIO.....DG said a minumum cure time of 12 hours.......then AW after the next wash....
If you have not got the 101 yet..I would suggest trying the 501 Marine Polish then the 105...the 501 really cleans paint....and has a very durable sealant also....very slick and has a wet gloss to it....same as doing 101 and 105....
Al
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | » Popular Product Links | | | » March 2010 | | S | M | T | W | T | F | S | | 28 |
| | 28 |
| 1 | 2 | 3 | » Car Care Brands | | | |
