Page 1 of 2 12 LastLast
Results 1 to 10 of 13
    Super Member AustrianOak82's Avatar
    Sep 2014
    Indiana
    324
    Pre-Soaking Vehicle?
    For those of you that encounter poorly maintained vehicles that clearly haven't been washed in several years, are you pre-soaking them prior to the hand-wash? I have had a couple cars lately that were heavily oxidized and had years of bug residue, among other stuff everywhere, and was wondering if there was a way to make my life easier. Thanks!
    Super Member HUMP DIESEL's Avatar
    Dec 2013
    Gaffney, SC
    930
    Re: Pre-Soaking Vehicle?
    I usually do it even on one that is well maintained. I use Auto Finesse Avalanche Snow foam, but I am sure there are others. I put it in a foam lance and let it rip.
    I usually do this and then while it dwells, I get my 2 buckets with wash and mitts ready.
    HUMP
    Super Member wdmaccord's Avatar
    Jun 2013
    West Des Moines, IA
    1,278
    Agree with HUMP. I do it regardless. I usually use 6 oz. of CG Citrus Wash Red and 2 oz. Megs APC then add 24 oz. water in my 32 oz. foam gun. Set to middle setting. Foam once and let soak. Rinse. Then I foam a panel or two and wash with MF mitt, rinse, then on to the next panel or two.
    2016 Accord EXL V6 w/Navi & Sensing - Black/Ivory
    2019 Acura RDX A-Spec - Black/Red; 2019 Acura TLX Base 2.4L - MSM/Black
    2008 CRV EX - Black/Black 2003 Accord EX V6 - Black/Tan
    Super Member Audios S6's Avatar
    Oct 2011
    Shoreview, MN
    1,634
    I snow foam every vehicle that's not in for a maintenance wash. I use CG citrus wash & gloss with Bilt hamber surfex HD in the foam cannon. While it dwells, I dump my wheel bucket, put away wheel brushes, then get all the tight spots with a small brush and APC (emblems, grills, mirrors, handles, gas cap). Before rinsing, I'll get my area set up for drying and claying. Then rinse and jump into a 2BM wash; if necessary I'll re-treat lower panels with degreaser or tar remover just prior to the 2BM.
    So in some cases, I actually pre-soak twice using different chemicals since one degrease may not be effective on all contaminants (although surfex HD is pretty awesome stuff)
    Super Member JWilliams.RadiantDetail's Avatar
    May 2013
    710
    I spend an extra few minutes and pre soak every vehicle by default. I use CG Honeydew, it works good. I just switched to ONR+W, will probably figure out a good dilution ratio to use here for a pre-soak. I don't do anything different with the Honeydew, I use the same stuff in my foam gun I'll do the actual wash with.
    Super Member conman1395's Avatar
    Nov 2013
    Kansas City, KS
    1,622
    I don't do this for a living but what I do with my own car or others cars is go to the coin operated wash and use that to the best of its ability. Then I come home and use the appropriate products (Tarminator, IronX, Citrus wash, Degreasers). Obviously if you do this for a living then you'd have a foam cannon or at least foam gun; I do not.
    2017 Infiniti Q60 3.0t AWD
    Super Member VISITOR's Avatar
    May 2007
    9,723
    if you don't have a pressure washer, it's time to purchase one. if i was doing this as a business, there's no way i would be without one...
    Super Member Dr_Pain's Avatar
    Nov 2012
    South Central, Louisiana
    2,196
    Quote Originally Posted by wdmaccord View Post
    I have different product selections, and use a foam cannon instead, but in essence that is what I do snow foam + APC and let it dwell
    https://www.facebook.com/FlawlessFinishDetailing
    Dr. Claude Tremblay, Co-owner/Senior Detailer, Certified CQuartz FINEST Installer
    Super Member Sicoupe's Avatar
    Mar 2013
    Oklahoma
    3,352
    Quote Originally Posted by Dr_Pain View Post
    so you add the APC with the soap in the cannon?
  10. #10
    Regular Member JMP's Avatar
    Sep 2014
    North Bend, Washington
    182
    Foam cannon with Detailers Extreme Foam....works well on the cars...but I have not seen one with years of bugs and such....
  1. APC soaking towels used with coatings
    By wils91 in forum Auto Detailing 101
    Last Post: 05-20-2016, 11:13 PM
  2. Is pre soaking ONR really necessary???
    By fellipe in forum Auto Detailing 101
    Last Post: 08-31-2014, 07:54 PM
  3. Finishing pad soaking up product...
    By TH3M B0N3Z in forum Ask your detailing questions!
    Last Post: 01-25-2013, 07:23 PM
  4. Pre soaking
    By anson89 in forum Auto Detailing 101
    Last Post: 12-17-2009, 11:35 PM
  5. Cork Soaking (SNL)
    By aceshigh73 in forum Off-Topic
    Last Post: 10-12-2006, 09:03 AM
