Page 4 of 6 FirstFirst 123456 LastLast
Results 31 to 40 of 56
  1. #31
    Jan 2014
    Thanks everyone for all your input. I'm definitely trying the mitt and need to find somewhere that carries Clay magic.
  2. #32
    Jan 2013
    348
    Re: What's the best Clay bar?
    I like Ultima Elastrofoam.
  3. #33
    Senior Member CarolinasFinestDetailing's Avatar
    May 2011
    Indian Trail, NC
    1,489
    I use the Nanoskin mitt, and still use clay as well for wheels and lower valences where you tend to have a lot more contaminants.
  4. #34
    Junior Member Cricket's Avatar
    Aug 2013
    GA
    Quote Originally Posted by ShaunD View Post
    I don't think that statement holds true anymore since the clay patent expired. To the best of my knowledge Ricardo wasn't available in the U.S., and Optimum didn't start offering their clay bar until after the patent expired. That tells me that there possibly are some differences besides the aggressiveness.
    As far as the Nanoskin Autoscrub and the S.M. Arnold towels, stick with the fine grade. And make sure you have plenty of lubrication, and don't apply more pressure than necessary. This will help mitigate marring. For soft clear coat, dark paint, and doing small area decontamination, I usually reach for Pinnacle's ultra fine poly-clay. I haven't used any other brands' fine grade to compare it to but, for me on maintained vehicles, I prefer it over rubberized clay alternatives. I also like the ability to feel the surface become smooth and see what contamination is coming off the paint onto the clay; the autoscrub and S.M. Arnold towels don't allow you to feel the paint as well IMO.
    Now if you are doing larger, flatter, heavily contaminated panels then there is now beating the Autosrub on a DA. Or if you have some very stubborn bonded contaminates, like oxidized iron particles, then again the Autoscrub is going to be the best choice.
    If you have the money then maybe a fine/ultra fine clay bar, a fine S.M. Arnold towel or a Nanoskin product, and a Optimum eraser.
    Excellent - Thank you!
    fwiw:
    When I used the Nanoskin Autoscrub on very dark green (Emarald Mica 18J), I used the fine grade and applied NO pressure, very low speed (1 maybe?). It worked fine. I used lots of lube on the pad and on the car. I have the small manual medium grade Nanoskin pad, and it is too aggressive, imo, leaves some marring. Maybe I'll try it in the shower stall sometime, but regardless, it was way cheaper, so no worries.
    I used Clay Magic and loved it compared to Meguiar's and Mother's. I said earlier that Mother's was softer than Meg's, but I think I got that backwards - last fall - can't remember. Regardless, Clay Magic rocks and I found it at the local NAPA Paint Supply store. Their regular auto parts store didn't carry it, and it was cheaper than online by a lot.
  5. #35
    Aug 2013
    GA
    Quote Originally Posted by brehkop View Post
    I found Clay Magic at the local NAPA Auto Parts and Paint Supply store. The NAPA Auto Parts store didn't carry it. (see my post above)
  6. #36
    Quote Originally Posted by artofdetailing View Post
    Nanoskin products are more expensive upfront but wayyyyy cheaper in the long run if you think about how many uses you get out of them.
    i bought the 6 inch on the da. used it once and loved it. how many cars do u think u can do with it? and when will u know its time for another one?
  7. #37
    Member xabo's Avatar
    Mar 2013
    D.C.
    73
    Bilt Hambler..........you can use water as a lubricant.
  8. #38
    Senior Member ShaunD's Avatar
    Nov 2010
    Va Bch, Va
    1,254
    The insert with the Nanoskin Autoscrub says 50-80 uses. I haven't worn one out yet, but I'm assuming that when it gets worn down to the point there's no texture, and the edges around the circumference is showing the foam underneath, then it's probably time to replace it. As long as there is some polymer rubber there it will probably work, just not as efficiently as when there was more material.
    Shaun Shines Automotive Detailing, VIRGINIA BEACH, VA. http://www.facebook.com/ShaunShinesDetailing
  9. #39
    Senior Member Toxix's Avatar
    Aug 2012
    Toronto, Ontario, Canada
    209
    You guys are really selling me on Nanoskin...got some links to the products?
  10. #40
    Nov 2013
    Alexandria, VA USA
    1,072
    Quote Originally Posted by Toxix View Post
    Dude, AG sells it! Is it not difficult to find!
  1. Replies: 33
    Last Post: 09-15-2014, 08:52 AM
  2. ONR Clay Lube caused Ultra-Poly Clay bar to deteriorate
    By veilsideLGD in forum Auto Detailing 101
    Last Post: 02-20-2013, 06:42 PM
  3. Replies: 2
    Last Post: 11-12-2012, 10:50 AM
  4. Griot garage glass clay? Any differeny than paint clay?
    By heynicebits in forum Auto Detailing 101
    Last Post: 04-28-2011, 11:15 PM
  5. xmt speed clay or griots clay or megs mild?
    By jrt81 in forum Auto Detailing 101
    Last Post: 08-14-2009, 06:14 PM
» February 2017
293031 1 2 3 4
26 27 28 1234
